I kept asking the guy claiming to get 6” up 6” down to show he’s fully using the 6” upward travel and tell us how much bump stop he has set and he would not.
If you want a step-by-step how-to, this might help you out:
Why are you posting pictures of other people's rigs instead of your own?
The problem with you folk who don't know what they don't know is you tend to argue with those that do. For the sake of this discussion should it ever come up again, I did a little test for you to show you how full of shit most folks really are.
Rubi 44 front that I adjusted to 3" of bumpstop just for you. JJ front trackbar. This is maxed at full stuff with the axle centered.
Camera angle doesn't show the full number but it is 6 1/2" higher it is able to go, subtract 3" of bumpstop and you have another 3 1/2" of up left. If it isn't clear, I jacked it up to a hard full stuff, compressed the bumpstops down to 3", removed the trackbar, and then moved it up until it bound. You'll never get it that high, ever.
Too bad for you I bought the very last one in existence.Okay now do it with a jks because for the 100th time I don’t have a Currie track bar![]()
I think you misread my post. I said 35’s on the XJ30’sJKs and JLs can survive bigger. Ive seen enough carnage personally and know people way smarter than me in the industry that have confirmed my bias. I am of course assuming he has an XJHP30 because his avatar doesnt look like a 65wms+.
In my experience the older HP30s fail on the outer ends mostly. Ujoint, bent C, broken balljoints and failed unit bearing. Adding a hydro (again I know people make it work) just doesnt sit well with me. YMMV.
Ps love your thoughts and insights man.
I used to run a JKS track bar. After the 3rd heim failed in a very short time, I bought a Currie. Besides being more durable, it apparently supports greater articulation.
The Currie also provides better diff cover clearance.
These reasons and more are why it's a favorite front track bar for many on the forum.
Your solution seems like a lot of work to compensate for a subpar track bar. I think that just doesn't make sense to a lot of people who have better suspension flex than you without resorting to nonstock track bar mounts or bump stops that limit shock travel.
Wouldn't a Currie track bar be a simple, clean solution to your problem?
Or is there another reason to do what you're suggesting that's unrelated to solving your actual problem?
Comment: I would like to stretch the front forward a 2-3 inches and will need to move the frame side track bar mount. I'm considering a double shear bracket
I misinterpreted the post about max tire size on an XJ HP30 as well. Now that that is cleared up, I have a question and a comment:
For context, I have a locked XJ HP30 on 35s with 30 spline RCVs , spicer ball joints and Timken unit bearings.
Question: I really would like the help of hydro assist steering. What exactly is your concern with it?
Comment: I would like to stretch the front forward a 2-3 inches and will need to move the frame side track bar mount. I'm considering a double shear bracket with a heim and possibly a cross brace instead of another factory style single shear for strength. Increased range of motion is another perceived advantage but not a current problem with 9" of shock travel (although it seems like a possible issue with 11-12" shocks when I mid-arm). I'm aware @mrblaine has found the stock style bracket to be sufficient and Josh reports no issues with his set up.
Both could possibly be true according to what Mr Blaine showed with the Currie track bar. I don’t have one I have a jks. I’m going to do an axle swap and fabricate my own steering and track bar set up when I do and I plan to go double shear so I will need the frame side bracket cut off anyway. So to me it would be a waste in my eyes to buy a 500$ track bar and have to do all the work later anyway when I can buy a sub 200$ track bar and do the work of cutting off the bracket and welding on a double shear mount now
If you are going to do an axle swap soon and have to build custom steering and a custom trackbar you should be picking a bracket based on how easy it will be to cut off.
You're wasting time and money, not saving.
Dana 30 and TJ Dana 44’s use the same outers. So why is the 30 an issue?
Your logic is highly flawed due to the low number of big axle swaps and custom steering you've done. It would be a mistake and not a little one to assume or even believe you could use the same track bar frame mount for both axles. When you do the big axle and custom steering, you'd be retarded to leave the axle side trackbar in the same location as you currently have. That means that side changes. You'd be retarded to leave the frame side in the same spot and run the stock drop pitman, so that side changes. You will need a flat pitman, you will need to scoot the axle forward from stock more than a little bit. To avoid bumpsteer, (unless you're a retard who likes bumpsteer) you're moving the frame side, to line up with the flat pitman that is also a different length than stock.My whole reasoning in skipping the Currie track bar and going straight to double shear is over my plans to axle swap in the future as highlighted earlier in this post. I’m going to have to do the work anyway why not do half now and skip the $500 track bar in the process.
There is exactly zero interchangeable between the steering and trackbar locations at either end between what you have now, might have with your temporary trackbar and double shear mount, and what you will need for the big axle. Trying to make something work for both is a fool's errand.
