Hello,
I started the swap and ran into problem. 2004 TJ 4.0 42RLE converting it to AX15 using TJ bellhousing 2004 flywheel and 2004 manual trans crank position sensor.
The 2004 24RLE has the crank position sensor on passenger side above the starter in about the 2 o clock position.
My TJ bellhousing has the crank position sensor in the normal 11 o clock position (top on driver side).
I had researched all of this I thought this was only a 05+ problem, since the 2004 nv3500 used the 11 o clock position, I was surprised to find my sensor on passenger side.
I am trying to use TJ bellhousing (crank position sensor in the 11 o clock position), 2004 flywheel and 2004 manual trans crank position sensor. Is the engine going to run with my 2004 computer in this configuration?
I am hoping that their is a difference in timing of the windows on the flexplate and flywheel for the different crank position sensor locations. I am going to continue with the teardown will compare the flexplate with new flywheel. I will come back tonight and see if anyone has experience with this. Now that this happened I plan to get flywheel & bellhousing on and get the engine to fire before going any further.
