What should my caster angle be?
Hi there,
Any updates on this thread? Super curious to hear how it turned out. I have an 05 TJ with a 2 inch lift and I’m getting some shimmying once engaged in first gear. All other gears seem fine. Curious to know if my current castor @ 4.7 is what’s driving this issue.
Thanks!!
I’m on 31’s right now
Hi there,
Thanks!!
4.7 seems sorta low, especially with 2 inch and 31s, I would think you could get better than that. What most people are doing is if you have adjustable arms slowly increase the caster until it drives right or until you get driveline vibrations. Then back off a little until vibrations go away. It’s a compromise between pinion angle and caster. On mine I was able to get to just under 5.5 with 4 inch lift and 35s.
I’ve got 33” tires on a 4” lift. I’m having a bit of a wandering issue in - mainly on 2-lane roads that aren’t as “flat” as the main roads. I have to work a little harder on these smaller roads to keep it in the lane. It seems to really react to the angle of the road and want to pull one way or the other. It’s fine running around town on the wider roads, but when I get on the backroads, it’s a little iffy.
Anyway, I’m not sure what my current caster angle is, but I’m wanting to get an alignment done and tell them specifically what to set my caster at. From other threads I’m thinking it needs to be around 6 degrees. Does that sound correct?
I doubt your wandering is a caster issue. Wandering on pavement is just a bag full of jelly beans aka multiple sources.
Weak front shocks
Tire psi unequal
Steering shock weak
Uneven tire wear
Caster
Thanks for the advice!! I’ll give it a shot.
