New axle seal leak
Maximillion
Mass
So I replaced left and right axle bearings and seals. Everything seemed ok Dana 35 with 145k so axles were a little worn but no scaring or visible damage. Drivers side still leaking. Suggestions?
Sniff test. gear oil= dino turds, Brake fluid = well hell I dont know. Ridge on axle? , seal damaged going in? Did my 99 not to long ago and what a B getting the old ones out.
What did you use to remove the old seals in your axle? I've watched a few YouTube videos on this process and they were using a slide hammer in one and a set of brake spring pliers in another.
https://www.amazon.com/dp/B00BR1BV8Q?tag=wranglerorg-20
Reactions: GregBelleville
It was doing the diff bearings and figured why do the axle bearings as well. I bought tried every puller,slide hammer I could get my hands on and the bearings would not budge. I ended up using a section of pipe that fit thru the center of the axle bearing and was long enough to leave several inches into the pumpkin. I then used a 20lb sledge and worked around the bearings circumference and drove them out.
Ya so I pulled it apart and I did damage the new seal. Replaced with a new one, just waiting for the RTV to set up.
Removing the stuck bearing races on the 35 and 8.8 is very easy if you have a welder. Pop the cage out, remove the rollers, then run a bead inside the race where the rollers use to be. By the time you get your hood off, the weld shrink will make the race practically fall out.
Reactions: TheBoogieman
