Is it possible to phase out Jeep ECU with an engine swap?
Christian.mers
Point A to Point B
Huntington, West Virginia
Is it possible to phase out the jeep ECU while doing an engine swap? Could you wire the gauges and all the stuff people typically save with the stock ECU for on a separate ECU (Hypothetically let’s say this separate ECU is a Holley of some sort)
97-01 Dash uses a CCD bus to talk to the dash 01.5-06 uses a PCI bus so you'd need a PCM to talk to the stock dash. Now if you replace your gauges with something aftermarket then you could eliminate the stock PCM.
@Shank is doing a LS swap in his LJ and eliminated a lot of the stick wiring but is still running the stock ECM.
https://wranglertjforum.com/threads/4-8-swap-cross-country-lj.72216/
Dump the PCM and install a Auto Meter direct fit dash and gauges.
