In my experience, when several suspension parts are done at the same time, it is hard to remember what got torqued properly without marking the nuts and bolts with a paint marker or equivalent. Can’t tell you how many times I “thought” I torqued everything until a loose part while driving told me I didn’t. I always mark nuts and bolts now.
If I hadn't had other issues I wouldn't have found out I'd forgotten to tighten my front driveshaft bolts on the flange (t-case) side. And if they'd worked loose anymore I could have damaged my t-case or broken the bolts.
I just bought paint markers to paint my bolts.
Yes. I did everything all at once. Lift, axles, body lift, all mods. Everything was tight when I left for Moab but 1300 miles on a trailer then 3 days of wheeling literally shook my rig apart on the 4th day. I really should have used thread locker instead of anti seize and also checked everything after some initial use.
Doing everything at once can make it that much harder to do catch things. Also anti-seize should only be used on certain parts. Since you're in the rust belt it's hard to not to want to coat everything.
I'd ask some of the more experienced folks on what to use and on which parts.
