My first mod, to remove the PO's mods. Can't do bro lightbars. I run Baja's on my other rigs. We aren't having silly lights that scatter all over and bounce off the hood.
What a mess. But got it cleaned up.
I have baja squadrens in that spot, but yes baja everything
Almost 6 hours of the return trip wrapped up. No hiccups except one Crank Position Sensor code and missfire around Raleigh a couple hours ago. As quick as it happened, I cycled the key and drove 20min without issue.
Stopped to use the restroom, cleared the code and it hasn't happened again since.
Otherwise it's been getting about 15mpg and run like a top!
Got both fitting nicely.. off to paint tomorrow!!!
Replaced my ignition switch and ignition switch actuator after my Jeep nearly left me stranded at the office. Pretty easy replacement, and I wasn't sure about replacing the ignition switch but did it anyway just because. I didn't realize how sloppy the detents were on the old switch until I felt how crisp and nice the new one was, so I'm definitely glad I replaced it.
Good job , what parts did you use ?
I’m getting ready to pull the plug and buy me some 15” tires for my 2.5” lift. Will be getting the wheels soon. Went from a 4” to 2.5” in January and still running the 17s the PO put on.
Is the recommendation still 31x10.5/15 for that size lift? That’s what extreme terrain told me but wanted to verify.
I have a set of 2004 Ravine Wheels with BFG KO2 Tires posted in the classifieds. I'm in Ohio
