That should move you up to 42mpg. Maybe more 🤣🤣
Doesn't he need the Fram oil filter too, for those gains? :cool:
My secret weapon for 43 mpg. 🤫
I replaced the O2 sensors and reset the code. Much better low end performance heading into work.
I'll check the mpg next. I bet it's up at least .25 mpg. :ROFLMAO:
How do you reset the code?
I have a P0128 code.
- Changed temp sensor
- changed Thermostat
- Flushed the whole thing and put new coolant in there.
Check engine light is still on.
Disconnect the negative battery cable for a couple of minutes. If the code comes back up in 24 hours, the problem wasn't fixed.
Front end Wednesday. Got my new raised winch plate and new to me rock crawler bumper all buttoned up. Good excuse to test the winch and retension the line, and I’ll see if I need to clearance the end of the plate so the soft shackles don’t rub.
Changed oil (casterol) and transmission oil (redline). Installed brute power fuel pump. Saved mopar fuel pump to rebuild with usa bosch motor i have. Checked gear teeth on speedometer, ordered new one. Removed some wiring and rear light from po. Put in new spark plugs. Replaced drivers side speaker cover that po put rocker switched in. Changed shift knob to a ball, old one missing center cap.
Busy day. Took off work just for this.
Removed my airbag switch since I've disabled them and put an aftermarket steering wheel on. It was tricky getting this to fit in the 2000 console.
Removed the MorRyde tailgate system and installed the Texas Jeep billet aluminum tailgate hinges. Also deleted the third brake light from the tailgate. I'm going to run to my rear cross bar and install a Rigid tail & chase light with the chase feature hooked to the parking lights.
If anyone wants the factory tailgate side third brake light wiring, I'll send it to you for the cost of postage.
