Ok I have good news, this is officially a rebuild thread?
I was able to get the ring gear out of the housing without applying any heat or force. I soaked it in denatured alcohol ( that's all I had on hand), held the assembly upside down and tapped the sides of the housing until I saw some brown sludge flow between the parts. From here I was able to smack the housing onto a couple of shim to get the gear to drop out.
I followed along with LR live on youtube (3 part series) :
This is a really great series of videos with lots of tips and tricks on things that are commonly seized.
After getting the ring gear out, I saw some pretty nasty corrosion where the bottom was sitting in water. There was also significant scoring on the side of the aluminum housing.
There was significant corrosion in the lever groove, deep pitting on the shoulder where the lever engages, and overall lots of surface defects.
This gear also had a lot of deformation from where somebody tried to crank on the lever with a pair of pliers or something.
The housing had a couple deep scratches, and corrosion at the bottom.
At this point I realized this sliding interface was going to need some serious work. I was able to get access to a lathe after hours to resurface my ring gear.
Let it soak in evapo-rust overnight.
Got it trued up in the 4 Jaw:
Brought in the diameter of each cylindrical surface as little as possible, the outer grease passage got about a 10 thou diameter cut, which addressed all of the highspots, and created a much smoother surface.
For the lever groove, I brought in the diameter about 12 thou, and did a 2 thou face op to each shoulder to ensure the lever doesn't get caught up in the future.
Then I went in with a file, brought down any nicks, and broke all the edges.
Finished it up with a red scotchbrite pad.
There is still a lot of deep pitting on the part, but none of it is rasied, the part is now a cylinder and there are no protrusions in the cutout for the lever.
The proper grease will make up all of the difference In this pitting, and the small amount I reduced the diameter.
For the housing I just honed the walls with a maroon scotchbrite pad, making sure to move the pad radially ( as opposed to in-out).
The left pic shows the original top of each part ( minimal initial corrosion), and the right shows where all the water pooled.
I also was able to remove the brake, I haven't really messed with it yet but it actually came out no problem.
next steps is:
- address if I want to refinish the exterior of all the components. Do you guys think paint matching it to the jeep would be tacky?
- Clean up and paint the drum.
- order a new motor
- make or order new gaskets/ seals.
Cheers,
