32RH transmission torque convertor switch
Replacement is already installed.
Waiting on a few replacement connectors for the wire harness rebuild project.
There is a GOOD chance that the wiring colors on the pigtail won't match your harness, so be intentional as you splice in the new connector.
Reactions: xXDavidCXx
Just about done with the harness rebuild.
For tape, I settled on Red Wolf wiring harness tape for the first layer
https://www.amazon.com/dp/B0BBV3NNTM?tag=wranglerorg-20
Then normal looms as required
Then the top layer is non-adhesive wire harness tape from Summit Racing SUM-165109 in .75 and 1 inch varieties
https://www.summitracing.com/parts/...TlB5uq9tj1xtiMl_bDZ_nQrQwfSW49Jq81TBYp-O08mA7
In areas that are in contact with the valve cover or other hot areas I finished with Painless performance 72022 anti-abrasion high heat tape.
https://www.summitracing.com/parts/prf-72022
I used liquid electrical tape for connections I could not put shrink wrap on, or other exposed wires.
https://www.amazon.com/dp/B0000AXNOD?tag=wranglerorg-20
Nice work. The worst thing that can happen by pulling the harness to inspect it is that you get all new tape & loom.
