Hi all,
I finally found a pair of half doors. They were nice and flush on the Jeep they came off of. I have two issues I need help with though.
The passenger side was difficult to close but I was able to move the striker plate out a bit and now it latches fine. But, it looks like the top of the door sticks out a bit from the tub. If I push the strike plate back in a bit, sounds like the bottom of the door hits the tub. The door looks straight to me but not 100% sure.
For the driver side, it latches fine but the bottom hinge pin doesn't sit flush with the hinge on the tub. I read another post that said the Jeep was painted after assembly. I assume the hinge plate on the door has some wiggle room to be adjusted. Doing so, will show the unpainted outline where the hinge is moved. I don't know if that would be more unsightly or the gap in the hinge pin. I assume the harm of leaving it as is would be all the weight of the door will be resting on just the top hinge instead of both hinges.
Help would be appreciated.
