Speedometer is still 10 mph too fast. At stop , it's on 0, stopping after driving to a light, it's on 0. I have checked the speedometer housing at the five oclock position and the 34 tooth gear. It's correct and in very good condition. It is not a proportionate error, it is a constant 10 mph too fast vs actual speed. I have reset the gauges with the odometer button press method and tried the battery disconnect-tap,tap,tap method.
I am still 10 mph fast.
I just did the "hold the trip odometer down and turn the ignition on" test again. It is my understanding that the speedometer needle should go to 20, then 55, then 75. Mine went to 30, then 65, then 85. So that's the problem, now how do I fix it?
