even before i started all of this i drew the line at buying an amp and all that
I know you drew the line, but I see several single channel amps under $50 on my local FB. Very easy to wire. You could forget about all that factory wiring and move on.
understood. i read a lot of complaints about the factory amp while researching all of this lol. one thing i saw mentioned in a topic somewhere, for someone who was pushing one of these subs on the factory amp, is that it kept throwing the amp into some sort of protection mode? i have no idea if that's what's happened or not, but even before i started all of this i drew the line at buying an amp and all that. if the PO had already done the work to install one (running the line to the battery, running the preout wires, etc) i'd be a lot more willing to entertain it, but i'm not gonna be the one lol I really don't want to spend any more money on this thing (and i still need to get the morryde tailgate kit). i'd rather spend money on my track rocket lol
thanks for all the replies, i appreciate you putting up with me
interesting. i saw plenty of videos on youtube of people who replaced their head units and subs and didn't get an aftermarket amp and it was all working. i don't know what we're missing though.
A sound healing school I checked out recently is using transducers in vests and chairs
I jumped on their website to look at the vests again and what do you know…
The pricing might not be for the do-it-yourselfer, but you see how they are implementing transducers in car seats
https://www.soundloungecenter.com/car-seats/
I've been thinking about this... and I'm gonna withdraw this offer. Not because of anything you said, but because if you don't know how to use a multimeter, you shouldn't be trying to figure it out on live stuff for your first go-around. I didn't put enough thought in before I offered.I'm hesitant to say this, but if you snap a photo of your meter, I can highlight those settings for you.
You're unlikely to hurt yourself with 12VDC. But it's a bit like saying, "I want to cut this piece of wood, how does this tablesaw work?" ...and then taking the advice of some stranger on a forum. Best to learn the right way before you dive in and do something that could get you in trouble.
how involved is the wiring? i'm sure running the rca cables isn't a big deal but the big deterrence for me is that i thought a "real" amp needs a line ran through the firewall to the battery, or otherwise spliced into another power line. if there are less 'intrusive' alternatives i'm all ears but i'm not committed enough for all of that, trust me it's not worth it for this vehicle.I know you drew the line, but I see several single channel amps under $50 on my local FB. Very easy to wire. You could forget about all that factory wiring and move on.
to be fair, i was being a bit reserved. i for the most part know how to use it- i know which settings are for voltage and continuity, etc- i just don't know where to put the probes, and what parameters/values to test for. i have a pretty nice auto-ranging one too (Klein MM450) to make it as brain-dead as possible lol
sorry again for being such a pain in the ass about all of this, i was always scared to do this shit back in the day; i always paid Circuit City to install my radio stuff LOL
Mainly, then, you just need to know what you need to look for. A head unit needs power. Power in most cars comes in the form of 12VDC, referenced to vehicle ground. So the black lead of your meter should be on a ground (bare metal of the vehicle or a wire connected to bare metal), and the red lead on whatever is supposed to have 12VDC on it. There's constant-on DC, and switched DC. Constant-on has 12V all the time; switched has 12V only when the ignition is on. Modern head units need both of those. Conventionally (but not always) red = constant, yellow = switched.i just don't know where to put the probes, and what parameters/values to test for.
No, you're totally right. It's crap.It’s crap and is wired very oddly. I think it only works with the factory head unit. Someone correct me if I’m wrong.
That's where things get murky. I don't know what you're testing for, and I really don't care enough to look into what the factory amp or wiring is doing. An amp has power and signal inputs, and outputs a signal to a speaker (or speakers). One or both of those inputs could be screwed up. If you can eliminate power as the culprit, then you can check continuity and resistance for the signal coming in. Or it might be your outputs that aren't working (blown? I don't know) or the wires to the speaker, or the speaker itself.thanks delta, that's all really helpful. so i can test corresponding pins in the 12 pin male connector (coming from the radio, to the sub) to make sure it's getting the proper power?
No. Definitely not. You should really only be checking resistance when current is not flowing, and there's zero voltage (AC or DC) between your test points.that kicker sub is 4ohm. i need it plugged into the car with the ignition on to test it for resistance right?
That is possible. It's also possible that they put it in and wired it wrong. That there's a short, or a ground, or a broken wire. I don't mean to be vague, but there's no way to be specific here.i'm pretty confident in my wiring of the radio harness; the head unit and speaker are all working properly, so at this point i'm pretty sure the amp is bricked. what i imagine happened is the stock sub blew, PO replaced it with a drop in speaker (a Pioneer TS-G1643R 6.5"), and that drew too much power or whatever and fucked the amp.
I'm not sure how else to help you. Maybe another member can give guidance.
If you're struggling this much, take it to a professional.
Good luck![]()
yall its definitely the fuckin blue wires. the takeaway i have from this experience is that while an aftermarket amp will have it's own continuous power wire to run to the blue/white wire at the radio, the factory amp does actually utilize the solid blue power antenna wire and needs it wired to the blue/white wire to tell the amp to turn on. it was literally just that; i pulled out the deck and hooked em up and it's all working.
thanks for sticking around while i worked it out
i didn't wire those together on purpose because of all the videos and posts i had seen about it beforehand; however, i did have the foresight to leave them with a butt splice connector on the end so they could be wired up in a few seconds 'just in case' LOL.Yes, those blue/blue white wires are the accessory power that turn it on when the key is in the accessory or on position. Sorry you didn’t catch that. It is mentioned in the thread a couple of times as accessory power. Glad you got it working!
I've been thinking a bit about how I want to go about an audio upgrade. Amp, speakers, sub are decided on. But I can go one of two ways with the interface:
I like #1 because it's stripped down. And I can use the area where the head unit used to be for a switch panel.
- Dash-mounted phone. No head unit. Bluetooth direct into amp. Line level from amp to sub.
- Double-DIN w/wireless CarPlay.
#2 provides more functionality... mostly a rear camera. That's the main difference, and I'm starting to think it's not enough of an advantage to go with a head unit.
There's a compromise I haven't given too much thought to: I have a Maxca unit on my motorcycle. Carpuride is a similar device. It's basically just a CarPlay screen. Audio would still have to be handled by BlueTooth to an amp.
I'm not at a crossroads yet because I'm putting off the audio for other upgrades... but it's coming.
That’s a huge factor for me. Being able to sock the phone away on a wireless charger somewhere out of the way is maybe more appealing than having cameras.Mine looks practically stock and no phone on a mount.
