Pentastar V6 in a TJ
Pentastar V6 . . . Has anyone done this re-power to a TJ?
Wondering the pro's & con's of a transplant into a 5sp. TJ.
Keep your TJ 'all Jeep' . . .
Thoughts . . .
I'd ask WHY???? For the amount of work you coulda had a V-8....
In all seriousness are you talking about the 3.6?
Who rev's their engine to 6,400 RPM's on a normal basis? And the torque peak is way higher than most would rev to also.
6 cylinders I'd use instead of that minivan motor:
Stroker 4.0
The GM inline 6 for the trailblazer
Toyota 2GR (this one's also a minivan motor but a way better one)
I can think of a V6 I'd like to have in my Jeep. Not sure that the front suspension can be beefed up enough to support it though. ;) :D
I can think of a mechanical inline 6, that’s heavy, that I would entertain drooping in.
No “V”6, though.
I've had the Pentastar V6 in a JLU and JT. I think they're pretty good engines but don't think I would put one in a TJ.
If I had a notion to do something it would probably be a 4.6L stoker. Maybe with the Edelbrock head to save some weight.
My 4.6l is a blast.the aluminum head almost makes it like the the winch isn't on there.
Starting with a gutted tj or 4cyl,I would be very tempted to do a GM 4.2l/4l60e with a low boost turbo. 100+ hp more than I have now and probably better mileage.
Though honestly I'd rather use a sprintervan 2.7l/nag1 diesel combo. I know of several near me with over 300k miles going strong and getting 20mpgs
