Replacing Coil Pack for Convenience
HDRider
NE Arkansas
I might just be wanting do do something for no good reason other than having something to do.
The last time I changed my spark plugs I found lining up the spark plug boots to be a royal pain.
What do you guys think about replacing coil pack on a rail with a coil pack with individual boots?
First, what do you say about the idea, and second if the idea has merit, do you like a certain brand?
Thanks
I looked at this, but am not wedded to this brand specifically.
https://rippmods.com/products/jeep-wrangler-tj-4-0l-00-06-coil-pack-upgrade-kit
Reactions: Spike Strip
I did the same thing on my previous XJ and recently on my TJ. I would suggest the K Suspension kit for the TJ. The bracket is also supported at the top and is very sturdy. Someone else posted recently about their RIPP bracket breaking.
I bought the bracket and extension harness from K Suspension. Then I ordered a 2008 Wrangler Blue Streak Coil and 1998 Wrangler NGK wires from Rock Auto. I also installed new NGK copper plugs while I was doing it. It all went together fine and my TJ is running great.
ETA: I'll add that I wasn't expecting more power. I was thinking it will make changing plugs easier in the future. Also, if needed, those coils and plug wires are pretty cheap and easy to change.
Thanks - I'm not looking for more power with this either, just make it easier to change the plugs next time.
If I can trouble you a little, is this the stuff you listed?
K Suspension seems to only sell the kit. Did you call them and ask for the bracket only?
https://www.ksuspensionfab.com/store/p149/TJ/LJ_Viper_Coil_Mod_(whole_kit).html#/
Coil
https://www.oreillyauto.com/detail/...28880/automotive-suv-2008-jeep-wrangler?pos=0
Plug Wires
https://www.oreillyauto.com/detail/c/ngk/ngk-spark-plug-wire-set/ngk0/53168
You were close on the K Suspension site. They will sell just the bracket and harness. Same page, but select Viper Mod Basic Kit. Select vehicle, then year, then kit bracket + harness. Should be $61.98. This page. https://www.ksuspensionfab.com/store/p281/Viper_Mod_Basic_Kit_(DIY/parts).html#/
Those are the coil and wires I used. May be a little cheaper on Rock Auto but after shipping may not matter much.
When I installed the bracket I put an extra washer on the bottom bracket bolts so they wouldn't bottom out in the bolt holes.
It all went together pretty easy.
ETA: Make sure you pay attention to the firing order. I used a label gun to mark my coil with the firing order.
