I didn’t! What’s the best way to request one? When my dad does his body lift at some point I’ll definitely ask, gotta rep the brand!
Comments section in the shopping cart fulfills that function quite nicely.
Changed the oil (Mobil 1) and installed a "Hood latch skid plate" that is made & sold by member sunnysideup_lj. Adds a touch of class to the engine dept.View attachment 600220View attachment 600221
How do you find "@sunnysideup_lj" for THAT plate?
Mounted the new 8-gang AuxBeam controller on my new switch panel. I just need to get a bit longer screws in the morning for final mounting. When I get the Jeep back, I'll drill the 2 holes for the USB charging ports on either side.
I can't decide if I want to stick with the 8-gang or send it back and get the 12-gang controller. The "Front" lights are going to have the bumper and A-piller lights on 1 switch with the 8-gang. I've been debating on getting a power inverter. Separating the front lights and adding the inverter would leave me with 2 open switches on the 12-gang controller.
Nice.
How do you find "@sunnysideup_lj" for THAT plate? Also, any leads on Mopar 55036369 rubber condenser seal around it?
I contacted this seller. They modified the file to be blank without the step and printed it for me. They were super easy to deal with and I had it within a week or so.I'm sure this has been answered somewhere, so my apologies. Did you print this or where did you find it?
Installed double adjustable upper arms in the rear to set up the pinion angle after installing a slip yoke eliminator and cv driveshaft. I have about an 1/8” of clearance between the track bar and the gas tank skid, not sure if I need an angled track bar bracket or not.
View attachment 601139View attachment 601140
