First Time Jeep Owner, Steering Issues
Jeepoftheseus
Phoenix Arizona
Hey everybody, I've been reading the forum a lot over the last 6 months as I prepared to buy my first jeep. I went with a 98' TJ 4.0. I got it at a great price, but part of the deal is that there are a lot of gremlins I need to chase to get things running smooth. I'm a long time shade-tree mechanic and will tackle almost any job that can be done at home on my cars and motorcycle. Being able to wrench on the jeep was a selling point for me, I think it's going to be a lot of fun. I definitely still have a lot to learn about the car though.
The steering on this jeep feels sloppy. The alignment is comically bad and she wanders a bit on the road. I managed to drive home safely an hour back from the seller's house and hit 75mph +, no death wobble. I haven't noticed any power steering leaks or problems. I've never had to do any steering work before nor had I driven a TJ until yesterday. The question that's really on my mind is how much dead zone/slop in the steering is normal compared to, say, my partner's Camry? Could the comical alignment be causing the slop? I'm trying to determine if I have other steering issues to fix before it makes sense to have the alignment done.
The seller flips cars as a hobby and didn't really know anything about the jeeps history. The engine and transmission feel good, and there's no rust on the frame because it's an Arizona jeep. The rear main definitely needs to be done too.
Any insight is appreciated.
welcome out from the shadows and congrats on the TJ 🍻
Eliminate the easy things like setting proper tire pressure in the mid to high 20s depending on tire size, do a dry steer test to look for worn steering components and lastly if the steering box is worn out the only remedy is to get a new manufacture steering box (preferred) or roll the dice on a reman to see if you can get one that wasn't rebuilt with a worn out bore.
I put Currie CorrectLync steering and track bars on my 97.
When I purchased my '01 the vehicle steering drifted at highway speeds.
I replaced the mismatched tires and aligned the steering; which helped slightly.
After a thorough front end inspection; I found the front steering tie rod ends to be worn.
Since I had upgraded to the JK 17" rims I installed a rebuilt Currie CorrectLync ($325) which solved the steering problems.
Another good alternative would be to upgrade to the ZJ front steering; information can be sourced on this forum in the Jeep Wrangler TJ Resources section under TJ How to Guides.
https://wranglertjforum.com/forums/tj-how-to-guides.109/
Hey everyone, your responses have all been super helpful and I'm well on my way to having the issue resolved. I've been able to improve the alignment a lot and it feels better on the road for sure, I'm thinking I may need to rebuild the steering box though because there is still slop in the steering that I can't seem to account for elsewhere. I've included some pictures. Does this look stock or aftermarket to everyone?
Looks stock to me. Except maybe the sway bar links?
My understanding with steering gear slop is that a rebuild is basically a reseal, while the slop comes from the bore inside wearing and isn't repairable.
That's really helpful to know, so I should probably be looking for a replacement unit instead. Anyone have any recommendations? Also, those sway bar links rattle like crazy when I squeeze em and shake em. Is that normal?
Reactions: lBasket
What the heck is that line running front to rear that is laying on your steering?
Google "dry steering test" then do it. Get help with the wheel. If you are methodical and pay attention you won't need to guess where the slop in the steering is.
Reactions: lBasket
It is a crapshoot buying remans from anywhere to hope you get a less worn box. PSC sells brand new ones I think, but they're like 1100$ or something. Some people say the redhead rebuilds are decent, like theyre more particular about which they rebuild to sell? But that seems less of a sure thing and they're pricey.
Yeah you basically have DIY sway bar disconnects going on, with pins you pick up from somewhere like Ace hardware. I had the same pins and setup once upon a time, they aren't a great fit and make a bunch of noise forsure.
OK, that is an EXCELLENT question. Here's what I was able to figure out. The line is attached to the break pedal, and let's out by the winch. I'm new to off-roading and have no clue what the benefit would be. Do you know?
Reactions: lBasket
Looks like something for flat towing? I'd get rid of it asap.
Lares and BBB have brand new steering boxes that aren't as expensive as psc. But again,I would do careful diagnosis before firing the parts cannon.
Reactions: lBasket
Yep like Ricky said this is the brake line for a ReadyBrake, I've got the same little clamp and nipple on the firewall.
https://nsarvproducts.com/products/rv-readybrake-towed-vehicle-supplemental-brake-system
Basically a surge brake for the Jeep for flat towing. You're not really supposed to leave it attached to the brake while driving it.
Reactions: NashvilleTJ and JMT
