Sony XAV-XA3200 Head Unit Install
I went with this adapters. I should have done this earlier, but I was too busy just enjoying the new unit.
Basesailor USB to USB C Adapter... https://www.amazon.com/dp/B079LYHNSR?tag=wranglerorg-20
Like you I just grounded that wire so it didn’t matter if my parking brake was on for rear camera or fresh BT connections. 👍🏼
Looks like I’ll be snagging that! I totally would have gotten lost in the sauce enjoying the new unit too. I’ll have to get an AI generated image of my Jeep like @AndyA.
Speaking of which, what resolution did you use Andy? Or does it not matter
Just realized my cable is a usb-c female, so I need a usb-c male to usb female. Guessing your unit must be opposite?
Jsaux usb-c male to usb female
Oh crap. I think I got to looking at so many I mistakenly bought the female USB- C and you’re right, I need the male USB-C. Back to the drawing board. Good catch…Ordered…
Reactions: Duner
Updated today with the nearly instant delivered adapter.
Worked perfect. So far no errors. Before I was having one error regarding loading changes.
Reactions: Duner
Good to hear! Looks like you “VOL” letters are also not lit up, wasn’t sure if it was intentional on my unit but now I know! I think I might grab a screen protector next 🤔
Right, the VOL letters are not lit up. The + and - are intuitive and I don’t even need to look at this point. I have a glossy screen protector on it, but it’s too reflective. I ordered a matte and it’s arriving in a couple days.
Reactions: Duner
Mind dropping me the link for the matte one? Haha
For updating the 5600, I connected a usb-a flash drive to my 1.5ft (iirc) usb-a adaptor, which lives behind the dash just above where you can see it.
Do you not load firmware into the 6000 similar to this? Or, is it the same concept, but your flash drive is a usb-c?
Same concept, but the wire connector from the unit is a female USB-C, so I needed a male USB-C to female USB-A adapter to upload from a common USB-A flash drive.
There was another way to do it that described USB tethering. It was 15-20 min in comparison to 5 min, so i didn’t bother with that route.
Reactions: MikeE024
1456 x 816
Andy
Reactions: Duner
Hello all.
I have the same stereo in my 2005 TJ Rubicon and didn´t liked the Sony mic so i took
Here are the 3D printed files and the hardware needed. All printed in PETG. The front camera mount was printed with 60% density.
Front camera mount hardware:
- 1x #10x5" bolt, phillips pan head
- 1x #10 nyloc nut
- 2x M6x50 hex head bolt
- 2x M6 nyloc nut
- 4x M6 washer
Microphone mount hardware:
- 2x M12 external circlip
Andy
Hello all.
I have the same stereo in my 2005 TJ Rubicon and didn´t liked the Sony mic on the sunvisor, so i took your idea but made a little different bezel (rounded shape), printed in PLA and mounted on the windshield trim.
Here is the STL file if anyone want to use it.
May be i will install a front camera in the future using your design. Thanks for sharing!
Reactions: FarFire70
