Question regarding Currie upper control arm Johnny joint
jxv1247
Stamford, CT
It's about time to replace the upper control arm bushing on the drivers side of my Dana 30, and was looking at options. Is it worth going with the currie press in Johnny joint vs something like a Moog bushing ? Fronts a 3 link if that makes any difference.
This is the Johnny joint in question
https://www.rockjock4x4.com/CE-9112M
That joint isn't big enough to handle the work of 2 joints so it won't work very well for a single upper. Truss it with a mini truss and put a lower joint and mount on top of the diff if you insist on a single upper.
Reactions: jxv1247
... Truss it with a mini truss and put a lower joint and mount on top of the diff if you insist on a single upper.
Something like this, as an example...
Reactions: jxv1247
