Do-anything LJ build advice
holley sells something like that don't they? i know theres one other out there i remember seeing but can't remember the name atm
I went with AEM because Holley wasn’t as functional for my engine package as I wanted but I believe they have passed the AEM now for capability but am uncertain.
AEM should do what I want but if I run into issues Holley will be the next stop.
Reactions: Rolled Over Rubi
IF.... he ever gets it built.... hehehe I can say this now since mine is driving.
how long did it end up taking to do the swap? with the 4.0 to 4.7 I can get it built easily within 2-3 days not counting machining and tuning if i have too. i'd have about 7 hours everyday for 2 - 1 1/2 months
Haven’t started installing. Took a year to get the crate engine/transmission package I ordered. I wasn’t as busy for that year as I am now.
Port and polish is coming along
Reactions: Rickyd
you're going to make me jealous and spend the unnecessary money I have already planned on using
Believe me after doing 3 engine swaps on the same Jeep I can tell you it never goes as planned and you always end up spending double what you planned.
Depending on the year of the TJ dictates which engine option you have.
Easiest for 97-02 is a Magnum V-8. either 5.2 or 5.9 Or you can do a Hemi or LS also. But if you want a working stock dash the Magnum or Hemi is easiest.
For 03-06 you have to go with a Hemi or LS if you're interested in keeping it legal. And same applies here. If you want a stock dash the Hemi is easier. If you don't care about the dash then the sky is the limit.
If i did end up running the hemi what all has to happen? obviously tranny and engine, would you have to do much with the wiring harness at all or would it need a complete overhaul like the LS
Just to add. If you did everything on the CHEAP.. and it was all used either junk yard stuff or market place you might do a LS for under $5K but I doubt it. Yes people have but they got some stuff for free or a killer deal.
For a Hemi swap plan on $10K minimum unless you find a deal like I did. And all said and done I've got close to $10K into my Hemi swap because I added the newer heads.
If you have a 97-02 and can find a running driving Ram/Dakota/Durango with less than 125K miles (hens teeth) you could do the swap for under $3K and have a running driving TJ.... But then you have to figure things like axles out..
You need to send the Hemi & TJ harness to Hotwire and they blend the two harnesses together for around $2200. That was why when that TJ with the Hemi swap already done was offered to me for $3K I jumped on it. Even with having the buy another transmission I was money a head. The only bad part was the seller thought it was a newer Hemi ( 06 ) but it turned out to be a 03 so I swapped out the heads to the newer Eagle design.
Edit: for either swap you have to do something with the wiring. With the Hemi you can have a stock dash.
So a lot of the times any v8 swap will require fab, tranny, engine (duh), wiring harness, pcm, driveshafts, possibly axles, possibly speedo, cooling, custom ac and heater lines, custom tranny cooler lines. prolly some other stuff im missing but that's the main gist of it. Sounds pretty painful time and money wise lol
Reactions: lBasket and Wildman
Depending on how complete you want it to be yes.
You'll need a new radiator no matter which engine you go with. If you have a Dana 35 rear axle you'll need a new rear axle. You'll need new hoses for the cooling system & if you have A/C since no stock parts will work.
You have to weld in new motor mounts & transmission mount. You'll need a new exhaust and depending on what suspension you're running it can cause issues. Read that last 100 pages of my build thread to see the PAIN of trying to make things fit.
You need the V-8 PCM for any of the swaps. The Hemi or Magnum PCM's will talk to your stock dash but you might need something to make the speedo correct.
As I said the easiest is the Magnum but that's only legal up to a 2002. You can build your own wiring harness for it. For the Hemi or LS IMO it's less painful to pay someone to build it for you.
Bottom line is those who say they've done the swap for $5K on a Hemi or LS did it with a lot of used parts and had a lot of the needed items on hand all ready. I bought the tools to make all my own lines for the A/C and other stuff which adds to the cost. But you'll save money if you have other things that you can repair too. But you can't compare the power of a V-8 to even a stroker engine. Does that mean the stroker isn't worth it? I don't know since I don't have one.
maybe but then you gotta fab mounts for tranny, engine, if you keep tcase you gotta do adapter plates otherwise new tcase, front and rear driveshafts, pcm, wiring harness, relocation of steering shaft, custom exhaust, new speedo unless you do some with the harness and pcm, conversion to throttle by cable unless you swap out for throttle by wire depending on model of LS. im also planning on doing all this at an automotive school within the span of about one and half to two months. An engine swap is also gonna end up causing problems I wouldn't think i'd run into. At the moment a stroker and supercharger sounds easiest than swapping the drivetrain an redoing the brains of the vehicle
None of that fab work is difficult or expensive.stand alone harnesses for an ls are easy to make yourself.
Biggest gamble is finding a healthy motor and trans to use
you'll end up having to get custom parts for exhaust, A/C, cooling, and then the standalone harness and pcm. if you can't find the vin matching PCM, would you be able to rewrite another or would it be better to get a standalone at that point? if im doing stroker everything is basically plug and play after getting the block and heads bored, polished etc. i'd have to tune for the compression ratio but in term that'd mainly be about it I believe
when making the diy wiring harness is it just a matter of moving pins, adding or subtracting wires. and a new pcm?
