No I didn't put any in the wheel wells. I felt like the tires would block too much light and no be effective at what they are actually for, seeing the ground around the Jeep.My Lux kit is still in the mail. I am replacing a cheap Chinesium set installed by the PO. They are positioned well but worthlessly dim. You didn't position any in the wheel wells? Can I ask where exactly you put them? You used the eight light kit?
I used the 8 piece kit. It could be done with 4 on a TJ. I didn't realize how much light they put out.
Front frame horns
Rear frame horns (same on both sides)
Side Rear (same on both sides)
Side Front (same on both sides)
