Can't See Dash Overdrive Switch
2005 wrangler X ?
There And Back Again
Maine
2005 X auto 4.0L
I put in a set of 1inch seat risers from streetrays on my drivers side
and now I cannot see the overdrive light on the switch when i flip the switch to the OFF position
im also ordering a new seat cushion to put in that ive read will also bring the seat UP more
IS there a panel that will replace my original panel with out hacking it all apart that will bring the gang of switches out and Tilted UP so the lights are in eyesight
Mine has the switches on the left side and a flat plastic cover where the ashtray would normally go
Ill post pics if needed
also NOT wanting to move the switches from there location below the heater controls to the vent/switch adapters ive seen
thank you John
You could leave the switch like it is and add small led indicator lights in a visible location to alert you when one of the switches is on .
I added led indicator lights to the dash of our motorhome because I couldn't see the original turn signal indicator lights due to the steering wheel .
confused dean winchester GIF
Problem solved!
