This is why I hate NSG transmissions
astjp2
TJ Guru
Utah and Alaska
Well this is transmission 2, not sure if it’s any good or not.
  • Wow
Reactions: John Cooper
I wouldn't worry about that too much unless you're hearing bad noises, but, as you know, I dumped my NSG because R went out.
Reactions: Rygrego
If you can't find 'em, grind 'em!
:geek:
I don't recall seeing that when I swapped to Redline a few years ago on my '06.
Reactions: astjp2
I don't see any issues there. Is it shifting and driving ok? All transmissions will produce some metal and the magnets inside the transmission are there to help keep those metal fragments from traveling around in there.
Reactions: Tob
Well both transmissions were junk, shipped them both off to hi-impact in Memphis on a pallet, the second core is paying shipping. Hopefully in 2 weeks I will have a rebuilt and upgraded one back. Then to deal with the atlas that has a bad bearing in it. I may just rob the one from the YJ and stuff it into the LJ to get it drivable. Once it’s good, I will be over to Tom Wood’s to get a front shaft. And off for inspection and registration! After 5 years of owning it, maybe by Christmas I will be legally able to drive it.
What was wrong with them?
Maybe I misunderstood. Were the two transmissions you're talking about used or already rebuilt?
Reactions: williambmac
Please let us know how the experience was with Hi Impact and how the transmission behaves after you reinstall.
May need to send mine to them at some point.😒
Thanks in advance,
David
