So I had a few comments on the Tiburon seat thread but I am going to go through my process to put 2007 Mini cooper s seats in a 1999 TJ (so 2003 on - your results may vary). The goal is to make 2 plates that allow a simple swap of the seats on the existing base. I am also hoping to get the tumble function to work but that will likely require the bracket on the original base to either be moved or replaced. The cable in the mini cooper is there and should work but the spacing is not quite right to just drop it in.
I started by removing the passenger seat and then measuring out the holes (see the tiburon thread for this bit). After a lot of trial and error using carboard I then made a few plastic brackets and then a few more modifications and finally an aluminum test set in 1/8". The seats now touch but do not interfere with the roll bar in the back and the door pocket in the front.
In the pictures the red circles are the TJ seat studs. These now secure the adapter plates down. The blue is the seatbeat bolt which is retained in the factory position. The yellow is the tumble mechanism.
In the next pic with the blue plastic I realized that the holes for the mini had to go back to allow the original stud to have enough clearance (luckily the mini seat frame jogs in) and it also gave better clearance to the seatbelt on the other side.
The clear is my final plastic version (cracked out when I tried to fit it).
The holes on the mini are asymmetrical (304mm on one side and 200mm on the other) so another adjustment was made. Then the aluminum brackets bolted up and to finish it off some pics of the seat and the clearances. Basically it just barely fits. The worst spot is on the seat belt retractor but it will flex past it or if the height is raised it will clear it fine. This might get a little better with 1/4" steel instead of 1/8" as it will be raised up just a little more. I will have to make sure the original studs will work with 1/4" plate.
The aluminum is far to bendy but good enough to get in and test it all out.
Now on to the driver side for a bit.
Side note: The bolsters are a bit of a pain to get over in real life.
