M
mojowrangler
Guest
Automated system warning: this post is longer than a tweet. If that is too much for you, please move along.
My concern about wheel spacers started with a comment I saw from someone on Facebook that "wheel spacers are dangerous". After some research on my particular situation, I think the "dangerous" part is entirely situation dependent and I don't feel like I'm in any kind of imminent danger because I have wheel spacers. Not that it makes me feel any better, but I probably can find 20 other things I'm more worried about failing first and causing safety issues. But this got me thinking about whether I should leave my wheel spacers on since I don't believe I "need" them now that I have a different set of wheels and tires.
Potentially relevant info:
- I have a 1997 Jeep Wrangler with a 3.5" suspension lift, 1" body lift, Dana 44 axles, Jeep TJ Moab wheels (5" backspace, 0.5" positive/inward offset), 286/75R16 KO3 tires (32.8" diameter), and 1.25" spidertrax wheel spacers.
- The vehicle is used primarily for wheeling (not an everyday driver).
- The +0.5" offset and 1.25" spacers give me an effective negative/outward offset of 0.75". I could leave the vehicle in this configuration or remove the spacers, reducing the wheel width/stance by 2.5". I believe the tires will still clear with steering maxed out and the spacers removed, but I would have to test to be certain.
- I don't care as much about the looks as I do about safety and strain on vehicle.
- I believe the only advantage to keeping the spacers on would be increased width for cornering and off-camber situations. I believe the advantages to removing them would be less strain on the vehicle, less parts/failure-points, and narrower tire-to-tire-width for tighter trail situations. However, it is difficult to quantify these advantages/disadvantages, so I'm likely to just leave the wheel spacers on for now.
- The wheel spacers are from the previous owner. I purchased the vehicle with a different set of wheels (17" WER wheels with 35X12.50R17 KM3 tires with near full tread life). I might still need to put the spacers back on if I decide to use the "old" set of wheels and 35" tires (e.g., to take advantage of the tread life during warmer months). I'm not certain, and would need to test (steering clearance). However, I'm leaning toward keeping the 285/75R16 (32.8") tires on Moab wheels in the long run (noticeable increase in performance, presumably due to tire diameter, rotational weight, and 4.1 axle gearing). I might end up just keeping the new Moab wheels and 32.8" KO3s year-round - not enough experience with the new set yet and still deciding.
- I'm dreading if/when I have to remove the spacers because they are likely "frozen on". I had to use penetrating oil overnight, then a breaker bar to free up the lug nuts when I first replaced the wheels. I'm not sure if they were over-torqued or had just not been removed in years. Given the relatively new tires (within a couple years), I assume they were at least a little over-torqued without any anti-seize compound used. I assume the spacers have been on much longer without ever being removed and likely had some kind of Loctite thread locker compound applied. From previous owner documentation, I suspect the spacers were installed around 2009 (impossible to know if they've ever been taken off since then). If I do take the spacers off, I assume I'll have to use some combination of penetrating oil, heat, and breaker bar (and hoping nothing more extreme that involves cutting, drilling, etc.!).
