There is an interesting discussion starting in another thread, but I really don't want to clutter up the intent of the original post.
The discussion is around the plumbing of auxiliary transmission coolers. When I had my 32rh rebuilt, they also installed an auxiliary cooler and bypassed the radiator cooler completely. It's been awhile, but I believe they said that the auxiliary cooler would keep the trans fluid cooler than the cooler at the bottom of the radiator and the radiator cooler would introduce additional heat. Note that I live in the southeast so I have no need to warm the transmission fluid, I don't ever see cold mornings where that is an issue.
Anyway, a few interesting posts popped up in the other thread:
These two gentlemen bring up some good points.
It seems that there are a few running debates on how to properly plumb in an auxiliary cooler:
Transmission > OE Radiator Cooler > Auxiliary Cooler > Transmission
Transmission > Auxiliary Cooler > OE Radiator Cooler > Transmission
Transmission > Auxiliary Cooler > Transmission
I know that our TJs want to run at 210 degrees, but what is the temperature of the fluid in the radiator when the Jeep is up to operating temperature? Is it 210 degrees?
Is there a chance of heat soak from the coolant in the radiator to the transmission fluid in the OE cooler in the bottom of the radiator?
The ATF cooling tube in the bottom of the radiator is a timed tested method that is as or more effective than a stacked plate or tube and fin external cooler (compare fluid to fluid heat exchange rates to fluid to air heat exchange rates.) It is still the primary method for cooling automobile ATF.
Unless the ATF cooling tube in the radiator is damaged or defective there is no reason to bypass it. In fact, bypassing the radiator and and re-routing ATF to an external cooler alone often results in less cooling, not more.
For a TJ an external cooler should be an add-on, not a substitute.
The fallacy with that argument is that the ATF cooling tube runs through the bottom of the radiator adjacent to where the already cooled coolant is returned to the engine. The temperature of the coolant in contact with the ATF cooling tube in a warm or even a hot engine is well within the normal operating range of ATF, never at 200 degrees.
Yeah I was just using that number as an example. But let's say it's 150 degrees, that still means that it is unnecessarily heating your transmission fluid up if the transmission was operating at 120 degrees. Like I said, some people will disagree with me and that's just fine, we all have our opinions and experiences and I have zero experience with jeep transmissions, just other experiences.![]()
