Build plan for 33s
Not my jeep. This is 3.5in lift, 33x12.5 on 15x10s. Almost exactly what I’m looking for. My jeep is also a green Sahara
Thanks for correcting me on gear ratio.
Wrangler folks call them 4.10, because Chrysler did. But actually, either 4.10 or 4.11 is correct, and identical. Other manufacturers may always call it a 4.11. Same with 4.55 and 4.56. That's because the actual ratio, on the 4.56, is usually 41 teeth on the ring, and 9 teeth on the pinion, for 41 / 9 = 4.55555... So you can round down and call it a 4.55, or round up and call it a 4.56. The same applies to most gear ratios.
Not identical… ring gear diameters are diferent.
4:10’s in the front Dana 30
4:11’s in the rear Dana 35 or 44
Well of course the diameters are different. But the ratios are the same. The pinion gear diameters are different too. Count the teeth, do the math.
Dana 30: 41 & 10 teeth ring and pinion, respectively. That calculates to 4.10.
Dana 35: 37 & 9 teeth, which calculates to 4.111111111111111.
Ok, I made the assumption that most gear sets were like the ones I saw, where both the Dana 30 and Dana 44 were 41 and 9. I don't know the brand, it's been a while. I stand corrected (and glad to learn something).
Those specs are from Spicer. I assume most other brands are the same tooth count. I recall the situation was similar with my Nitro 4.55/4.56 gears.
1997, 4.0, auto, 30/35. Not my daily driver. Mostly street use and light - mild off-road. (South Alabama is mostly mud and I had enough of that in my younger years) I want to stick with 33s and try not to have to get into control arms or sye. This is the setup I plan on going with. Is there anything I’m missing or anything you would change and why?
DPG off-road ultimate kit:
  • 4-OME Sport Series Shocks
  • 4-OME Coil Springs (HD springs)
  • JKS “Quicker” Disconnects
  • JKS 1.25″ Body Lift
  • Brown dog mml
  • JKS Adj. Track bar (front) JKS Adj. Trackbar (rear)
  • DPG 2″ Extended Bump stops (Front & rear)
  • JKS Adj Rear Swaybar End Links
ZJ steering
4:11 gears
Truetrac in rear
33x12.5r15 bfg ko2s
15x10 Micky Thompson classics
  • JKS 1.25″ Body Lift (NO)
  • Brown dog mml (NO)
No on Brown Dog, no on jks body lift.
I’ve been told to go with the black magic body lift. Why no to the brown dog? They are the rubber bushing ones
My jeep is running 33x12.5r15 with 10in wide with 3.65in back spacing. There is a lot sticking out. So much so I can’t even slightly pass for fender laws. Mud will get flung everywhere but you’ll never rub on anything metal. You will rub on fender flares at stock height because they stick out so far. I highlined the stock fenders to not rub so much but different flares would have solved that issue as well.
I've had a few different guys ask me if i swapped wider axles into my rig when they see the 15x10's and 33's. It's a bit much. Lots of caster and tight suspension makes it drive ok albiet darty and wandering a bit. I'll be going to 15x8's with the next tire change
Can definitely feel the bad scrub radius when roads have ruts in them. I wouldn’t have gone this wide if I knew how bad it was back then. I will be swapping to jk 7.5in wide wheels with 2in spacers soon.
Reactions: Rickyd
1:100th is less than the difference in tires. Manufacturers do it all the time. 4.09,4.10 and 4.11 are used interchangeably.
For vibration reasons it is best to stick with stock style mounts unless you want your dash and other parts of the jeep singing to you at idle and low rpm
Because the rubber bushing Brown Dogs are known to increase vibes. I used them for 7 years. Then I swapped to MORE with rubber bushings for 3 months with little change. The best is your OEM motor mounts with a 1” spacer (JKS, Rough Country, and others make an aluminum spacer.
Reactions: Rickyd and Murf926
UPDATE. How is this?
  • OME Sport Series Shocks
  • OME Coil Springs (HD springs)
  • Black magic 1.25″ Body Lift
  • 1” spacer mml (stock mount)
ZJ steering
4:10 gears
Truetrac in rear
33x12.5r15 bfg ko2s
15x8 Micky Thompson classics
  • Brown dog mml
ZJ steering
4:11 gears
Truetrac in rear
33x12.5r15 bfg ko2s
I bought this exact setup back in 2020. I would highly suggest you not buy the Brown Dogs and the JKS body lift. The brown dogs were replaced a few weeks after installation after chasing horrible vibes at idle, and the jks had to be replaced because they indeed squished. I have pics to prove it but don’t feel like digging. Also, Dirk disappeared off the map when I had problems with some JKS parts I received.
What did you go with for mml?
JKS blocks and crown motor mounts. Couldn’t find Mopar because I decided to do my lift during Covid. 4 years later still no problems. Find mopar if you can though if you go that route.
Add a MORE 1 in steering shaft lift in your build too. Puts the shaft back at a good angle and gives you a chance to lube the bearing in there.
I installed the jks aluminum block MML with anchor brand OEM style rubber mounts a few months ago and haven't noticed an increase in vibes. I don't think the Mopar mounts are still available.
To OP,
If your factory motor mounts are still good, it's completely up to you whether you want to replace them or not. When I did my MML last summer, I inspected my 20 year old factory mounts and they were fine, so I didn't replace them. I probably would have if I could have found Mopar mounts at a decent price, but I couldn't. Just something to consider if yours are still good.
I decided to go with Rough Country for my MML. Rough Country is generally a company to avoid, but the MML is literally just a block of aluminum. Hard to screw that up. It was considerably cheaper than others I found, so I bought it.
EDIT: I just checked Amazon and it looks like the RC and JKS MML are the same price now, so disregard my 2nd paragraph.
