Utah Soft Shackle Recovery Points
I am not printing anything. 3D printing is like setting up gears, I got enough garbage running around in my head that I have neither the inclination or time to deal with learning the rarely used skill sets for either. I pay gear guys and I'll pay a 3D guy if and when we get it figured out. Or, I may just get out my pocket knife and whittle it out.
Well I hope it materializes as I like to see good ideas
My "good" ideas may not be what most consider good. We have no need for a factory head unit that eats up a lot of real estate in a TJ. The 1.5 DIN area is also not large enough for what I want it to do. So, we did a radio delete panel and then added the items we wanted to it and now we are working on a lay-out and how to make it all fit so I don't have to modify the double DIN bezel. I will if I have to, but I'd rather not.
Once I get this finalized, then it will go to a 3D printer to get made into what we need. I can and will do it all myself if needed but I want the lettering for the Rubicrawler air shifter printed into the plate on a raised platform that mirrors the radio control on the left side of the Switch Pro panel.
My "good" ideas may not be what most consider good. We have no need for a factory head unit that eats of a lot of real estate in a TJ. The 1.5 DIN area is also not large enough for what I want it to do. So, we did a radio delete panel and then added the items we wanted to it and now we are working on a lay-out and how to make it all fit so I don't have to modify the double DIN bezel. I will if I have to, but I'd rather not.
I like it, something different.
8 switches for the Switch Pro, Blue tooth controller for a remote receiver, 2 USB ports for charging, 2 seat heater controls with 6 position switches, clock with temp and voltage, and the Rubicrawler mode indicator all in what is basically wasted space in a TJ is not a bad thing. Almost as cool as this, not quite, but almost.
I need to get the comparison pic for what MOST see out of their rearview mirror to get the full effect across.
This is with a smaller than 35" tire. A big portion of that white car will be hidden with a 35 is my guess.
Reactions: mrblaine
Can you provide any dimensions...
Note: These are first-gen. I radiused the outside chamfer with a file and had them hard-anodized myself. However, I don't think any of the critical dimensions changed with the second-gen design.
Height at Front (tallest) = 1.9"
Height at Rear (shortest) = 3/4"
Width = 1-1/4"
Length = 4.2"
Edited: the shortest height was wrong in my original post - I hit the zero button on the caliper and didn't realize it.
Scott, Scott, Scott…. Mixing decimals and fractions? You are an Engineer!
Adding a post to highlight that the original post had a wrong height for the rear. Don't rely on the original post if you got an email alert - read the edited one.
Actually, that was done on purpose. As an engineer, I was trying to interpret the original designer's intent. Due to machining tolerances, I try to do that. The ones that are decimal didn't measure close to a fractional equivalent...
Reactions: chili_pepper
Well, you're certainly not an architect, otherwise you would have left a few dimensions out....and you would have cheated/rounded the ones you offered up... :sneaky:
Well, you're certainly not an architect, otherwise you would have left a few dimensions out... :sneaky:
Well, I am currently practicing as a civil, so if it weren't for my mechanical degree and experience, I probably would have! :sneaky:
Even the civil guys are far better than the "we just make pretty pictures, someone else makes it work" people... ;)
If you're a mechanical guy, you know dimensions are important. Some things matter. :)
Reactions: sab
Yeah, when I started hiring civils seventeen years ago, I was so appalled with their fundamental lack of understanding common dimensioning practices that I pulled out an old drafting textbook and put together a white paper on dimensioning that all new hires had to read. I didn't even attempt to explain GD&T concepts. I'm afraid their heads would have exploded...
They most definitely would have exploded....and someone's gonna have to clean that up! :ROFLMAO:
In all fairness, been many decades since I did any GD&T, I've likely forgotten more than I remember. Currently achieving my thousandaire status designing in wood.
Well if you are a civil engineer than I would have expected dem. such as 1" = 20'. 🤣
I still have a handful of these available. Not sure if I will be making more once they are gone. PM me to order a set.
Reactions: BC Moto
