M
mojowrangler
Guest
I purchased a blue ox towing system (got a deal on FB Marketplace and impulsively bought it because I know I can resell it for at least what I paid). I was hoping I could flat tow my Jeep using my Ram 1500, but there's a bout a ~13.5" difference between the Jeep's bumper mount points and the truck's hitch receiver. The tow bar warns that the towed vehicle hitch should be level or no more than 4" higher than the towing vehicle mount points. Without researching and measuring first, I assumed I could make up any difference with a hitch riser. However, hitch risers seem to only go up to about 10". I assume if I look hard enough that there are specialty risers I could use, but I'm also guessing there's a good reason I'm not seeing any risers over 10" (I assume it starts putting leverage/stress on the hitch receiver). So now I'm planning to pick up a car hauler (dovetail trailer with ramps). I see old/used car haulers that would work that are around $3K, while new the ones are around $5K+. I might pick up a new one today. While I'd rather not spend the money, hauling the Jeep on a trailer will put less wear and tear on it than flat towing and I won't need to remember to get the transfer case, etc. setup for flat towing (I've read/heard some bad stories about folks doing this wrong).
This is the trailer I'm thinking of getting (top of my list out of a few others I'm thinking about)...
https://murdocktrailers.com/inventory/cargo/details/936445/2024-PJ-C5-16-Dovetail
If anyone has advice on flat towing a lifted Jeep versus trailer towing (especially for this particular trailer), I would appreciate your insights. If it wasn't lifted, I think flat towing would be the way to go.
Some other details... I measured my Jeep from front bumper to rear spare tire and it's about 14', so this 16' trailer (including dovetail) should be big enough. I believe I measured tire width at 78" and the trailer would accommodate up to 83", so a little tight, but should be fine. The Jeep factory weight is around 3200 lbs. With all the modifications (lift, axles, etc.) I assume I'm around 4000 lbs or under. The trailer has a GVWR of 7000 lbs (2 3500 lb axles), so I'll double check the trailer weight, but it should be under 2000 lbs, leaving me with at least a 5000 lb payload capacity to work with. I'll offset the cost a little by selling a 5X10 utility trailer, which the car hauler can double as, and the blue ox tow system, but I'll also need to pick up some other things (straps, spare tire, etc.). I'm less worried about cost ($5K price point seems fair for a new car hauler), and more concerned about long term safety and usability. I'd consider picking up a bigger car hauler for other things, but I have small side yard I'll be storing this in and need to keep it under 20'.
I also consider a tilt trailer, but the dovetail design seems like it will be OK for my purposes.
