I have a little bit of experience with towing and trailers, but I’m hoping to get some guidance as I’m looking to purchase one to pull behind the TJ.
Background: I am currently remodeling my entire house and have been borrowing a truck and trailer when needed, which can be inconvenient, extra liability, and I don’t like being a moocher! Use would be all on-road, and only pulled by my 4.0L TJ (for the foreseeable future). I have never towed with my TJ, but I will soon install a hitch receiver and 4-pin wiring harness. At this point in my life, I believe a trailer would be a good investment.
Things I expect to haul: lumber, 4’x8’ material such as drywall and plywood, appliances, pre-hung doors, my lawn mower, C&D waste, bags of concrete mix, etc.
Initial thoughts: I will only be hauling this with the TJ, so I don’t want a trailer with a disproportionately high weight capacity or size, as it will be heavier and take away from the actual payload capacity I can pull, which I believe is only 2,000 lbs with the TJ. With this in mind, I think 5’ x 10’ is a good size to carry the items I listed above comfortably without being too big to handle.
1. What’s your thoughts on the 5’ x 10’ trailer size for the TJ?
2. What's your thoughts on new vs. used? I don’t mind re-decking, rust cleanup and painting if it saves a few hundred bucks. Any tips on inspecting used trailers, red flags, manufacturers to avoid, etc.?
3. At what point do I need trailer brakes or any other safety towing accessories like special hitches, etc.? (I am totally uneducated here). I do have a BMB brake kit with great stopping power.
4. Any tips on types of axles to look for? Is trailer suspension a good thing to have at that size?
Any other relevant towing education is appreciated by this ignorant gen z’er! Thanks in advance!
