again.. unless someone has a 231 and 242 side by side can't really answer that unless you give us something to measure their 242 from that is common between 231 and 242.... like say one of the bolts they mount to rear of trans..
length...... it is reported they are 1" longer to end of rear output shaft but that is an iffy measurment though likely not longer.
this might help. Have no read thru it
[URL]https://www.cherokeeforum.com/f2/np231-vs-np242-mount-height-comparisons-207326/[/URL]
Thank you, I had not found that thread, it provides some useful information, if they are correct and the 242 hangs 3/4 of an inch lower than the 231 we know part of the height difference.
I apologize, I didn't think I was being unclear, length from the mounting surface to the transmission to the end of the rear output shaft as that would be the measurement that will affect the rear driveshaft length.
