It did work for me, but it took the 3 things I mentioned to get Sonoran Desert cool after the SC was installed.
I doubt its Oil pressure.
Few questions: You have a new engine I think. What compression ratio are you running? THE OEM engine will run off pizz it about 8+/- : to 1. If you replaced the pistons with high compression, say 10:1 that is going to generate a lot heat.
Auto or stick? Auto will put out a LOT of heat, especially in the summertime. I know some guys out in Phoenix that were adding heavy duty trans radiators...
Can you run 87 Octane or do you need to run 89 or 91?
What temp is your thermostat on the engine??
Good question about the compression. Not sure. Would have to check with my mechanic. I doubt he replaced the pistons because it was a manufactured engine from jasper.
It’s a stick
I can run 87 in it. I’ve tried a whole tank of 91 in it before and it didn’t change anything.
Temp from my obd shows 230-240 at the hottest before I need to pull over.
