I won't go into a huge description as I've posted this elsewhere on here, but a new piece of data.
I've had a random misfire for nearly two years now. No codes, but definitely there and confirmed with multiple mechanics.
I have replaced:
Plugs, wires, cap, rotor
Distributor
CPS (mopar)
TPS (mopar)
IAC (mopar)
Throttle body
MAF (non-mopar, but since it didn't improve anything I switched it back to the factory one)
O2 sensors (NTK/NGK)
Computer
Timing chain/sprockets
Smoke tested and fixed all vacuum leaks (a hose, throttle body, AC selector switch)
Smoke tested and fixed exhaust leaks (except one at the muffler, but I doubt it's involved)
Fuel pressure is one PSI below spec
Compression tested (one was a little low, but within 10% of the others)
Ignition coil (mopar)
I'm sure there's more, but I'm drawing a blank.
Where it's odd is, the first 10 - 20 seconds after starting the Jeep there's no misfire. When we replaced the timing chain/sprockets the first one to two minutes after starting the Jeep the first time there was no misfire. It doesn't change when it's hot, happens at idle or under load (though it's harder to notice when it's above idle), outside temperature doesn't seem to matter.
Two Jeep mechanics have scratched their heads and thrown up their hands. Another, who actually works at a machine shop and rebuilds 4.0s, says he isn't sure but it seems like the issue is electronic, but that was just based on listening to it, no actual diagnostics.
I'll try anything, but I'm just not sure what to try next shy of just pulling the head and driving it to a machine shop, which I'm loathe to spend the money on if it's just more from the parts cannon.
Does anyone have any ideas?
I have replaced:
Distributor
CPS (mopar)
TPS (mopar)
IAC (mopar)
Throttle body
Computer
