Crank no start
Snuggybear
California
OK, had the skim removed from PCM started for a while because I had to jump pin number 22 to the positive fried something in the PCM so they had to fix it. I’m expecting it back any day however it may have burnt problem through the wire that feeds pin 22 but lose connection in the connector, so the end of 22 does not have power hope this makes sense… Please help
Installed PCM... still crank but no start...PIN 22 has 2 to 4 Volts when the ignition is on... new relays but no joy.... can anyone help please...
it will probably start if i jump PIN 22 to the battery but i may damage the PCM again... maybe the ground... wheres the ground for PIN 22 (which goes to the ignition.)
Have you looked at the wiring diagram in section 8W of the factory service manual?
