I saw that too, and thought about asking if he was making a choo, choo train!
Ended up doing the front midarm on @02GreenTJ instead, but was able to put in my front RJ3" and his old rear 2.5 OMEs, actually sits pretty level. The old ranchos had me at 4.5 front 5" rear lift, this is currently at around 3".
Looks pretty level to me, and now is no longer a monster truck lol
(Ignore the rocker)
Nice dude! Looks like the JJs are offset from each other. I’d try to get them both neutral in the mounts, and also I would point that zerk up instead of down
Didnt notice that thanks for pointing that out! Do i need to remove the joint from the mounts or can i twist the arms to center them? And assuming this is to stop them from binding?
In a trek to settle some idle/driving vibes, i was fortunate to find the thread @AndyG made on his lo-pro mount vibe fix. I did the 1/8 thick rubber washers in the frame rail, grinded the middle piece, and put the washers inbetween the transmission studs and the mount itself.
No more idle vibes! The jeep is getting more enjoyable to drive every day ever since the midarm with new joints, ball joints, unit bearings etc.
35 KO2s, and a regear will make this even better... they will be coming "soon"
If I am seeing that correctly, how do you tighten the bolts onto the rubber washers enough to reach the proper torque value? Isn't this the JKS body lift problem?
Thats a great question that i actually dont have an answer to. Maybe andy knows? The bolts are rather small, i just tightened them to hand tight. Im sure ill report back if problems arise
