I've had lifters that were so bad that 7 of the 16 (International V8) had holes worn through the bottoms, and all had bottoms shaped like cereal bowls. When I drained the oil, big blue metal shavings exited the pan with the oil. I later learned that these were the ancient artifacts of a lost civilization once known to my engine as "cam bearings". Being that I had acquired the vehicle in this sad condition, I opted to rebuild the engine. Not sure of the order of its demise, but I think the bearings were going, causing enough cam slop/wobble to pummel the bottom of the lifters. It had good oil pressure, so I don't believe it was an oil delivery issue. Eh...who knows. Chicken, or the egg? Point is, as @StG58 pointed out, fix it sooner than later. Ugliness happens!If it's a lifter, fix it sooner rather than later. If it gets bad enough it will eat a cam lobe. With that being said, it may go just like it is for a good long time. No way to really tell for sure. Look at it this way, the lifter is already gone, probably. The cam is getting pounded by that lifter, even if just a little. I suppose that you could drive it until it dies, and then put a cam and lifters in it.
