Let's confirm your tire air pressure first by answering the questions in post #3 above first.For overall comfort and quality, would the Black Maxs be the best choice?
I have 33s, I think about 28 psi, but I’ve tried a few different pressures, and I know the zone nitro shocks are stiff
Go to 26 which is appropriate for a lightly loaded TJ. 28 is more appropriate for when it's fully loaded.I have 33s, I think about 28 psi, but I’ve tried a few different pressures, and I know the zone nitro shocks are stiff
Black Max shocks are awesome. Add an Oro Swayloc and you'll really enjoy life Dual rate sway bar is awesome.
As suggested play with tire pressure.
Do you have C rated tires? Or are they D or Es?
Just researching this ORO Swayloc, very nice. How is this different from the Currie Antirock?
It's a dual rate sway bar. I got the manual one. One position is super soft for off-road and the second is super tight for the road. Probably one of the most significant performance upgrades to my TJ. And that stiffer road setting really compliments the softer Black Max shocks.
Looking for photos of it installed or an install video. Wanna see it in place. Got any good photos?
I installed the Zone Offroad 3 inch lift kit a few months ago. It has worked very well, but goes over bumps and potholes really rough. I currently have the shocks that came with the lift kit, but would there be a very noticeable difference between them and Rancho RS5000x shocks?
"The first thing that impacts ride quality is road surface conditions.
I don't care about tire pressure or tire weight ratings or anything to do with tires except that they hold air, are well balanced, and run smoothly.
I've played with several JK tire and rim take-offs. Same size tire, same rim, the MT rides like dog shit, the street tire is one of the best riding tires I've ever driven on. It isn't as simple as load range."
mrblaine
It goes in basically like an AntiRock, but the bar has an inner rod and and outer tube and one side has a tab that locks and unlocks to the arm using a manually actuated lever. The tab is attached to the stiffer bar so when you lock them together you get both inner and outer which is a stiffer street setting, and when unlocked only the inner bar which is the off-road setting similar to the AntiRock.
Here's a couple of mine.
Here's a couple more, with a stock bumper setup. To be clear, this was just to see if it would fit with a stock bumper. To make it work correctly, anyone contemplating this combination would need to notch the bumper where the arms move up and down. That said, it's not an ideal setup and the Swayloc is better paired with a quality bumper. This was just to show more pictures of the Swayloc, as requested!
Similar experience here.As was said,
There is so much truth here. I spent a significant amount of time chasing a softer ride. In the end the single biggest factor was tires. While I was already running Black Max shocks and a 26psi tire pressure, the ride was miserable on a "C" rated MTs. I pulled them and switched to a "C" rated AT. That, in combination with existing Black Max shocks and a 26psi tire pressure made a night and day difference!![]()
My off-road is mostly fire roads, outer beach sand and light sand so the lighter setting on the SwayLoc might be wasted on me...
As was said,
So do we believe it to be as general as MT vs AT.
