And you’re wrong.
I’ll take some tomorrow morning. Everything honestly looks pretty decent other than the drag link and track bar angles from the lift.Some pictures of the front end components would be good for the folks on here to see problems. Your spacers and that set up would indicate maybe some other half assed work on the part of the PO ?? D
Remove your steering damper, set one end on the ground, then push down on it. Does it move rather easily?
Now multiply that force times a lot. Tell me that is going to stop the wheels from moving back and forth wildly once they get started. Wait, how did that get started? I have a steering damper.
All the damper does is mild dampening of road effects. Remove it and the Jeep should drive absolutely fine. It’s only there to dampen the harshness. Nothing more.
If some engineer thought the 50:50 damper would stop DW, he should have been kicked out of undergraduate education.
Ok,
This is me asking an honest question with no button pushing...
I have built and/or maintained a ton of SFA (and even 2wd with a damper) stuff, where just the presence of a damper or having a not blown out damper controlled oscillation.
Like completely dialed in front end in every way, where the addition or replacement of a blown out damper cured all that ales you.
How is this platform any different than every single vehicle that has ever left the factory since the beginning of automotive time with a steering damper?
Jeeps, and many others (ford, Chevy, etc) really only started putting them on vehicles mid to late ‘70’s… DW really wasn’t as big a deal with the leaf springs as it is in coil setups. Coil setups have way more points of failures that will be exploited by tires that are bad. (Balance, out of round, separated belts, etc). DW cause is always tires. Trigger is a bump. Effect is the opposite tires oscillating and jerking the front end all over the road.
what the damper does, it it attempts to absorb the oscillation before it really becomes apparent.
Absolutely cannot. Nope. The steering stabilizer, more correctly known as the steering damper, is strictly a passive device and it cannot cause shimmies or DW. It can temporarily mask the symptoms of DW fooling some into thinking it was the cause and cure but that's it.
If a steering stabilizer can go “bad” and allow death wobble, ...
This is where I have a problem with absolutes because it can to an extent.
No wall of text can deny it.
