Axles/Differential
Body/Doors/Exterior
Brakes
Cooling
Electrical
Engine / Sensors
Frame
Fuel System
Hard top/Soft top
HVAC
Interior
Lifts/Tires
Lighting
Off-Road / Trail Mods
PCM Related
- Backyard front locker and gear ratio change
- Dana 44 Axle Overhaul Bearing and Seal Replacement
- Ford 8.8 Axle Swap
- Harbor Freight U-Joint Tool Trick
- How to change a pinion seal on Dana 44 rear axle
- How to change the front axle seals on a Rubicon Dana 44
- How to change your differential fluid
- How To Change your Differential Fluid
- How to change your front inner axle seals on a Wrangler TJ
- How to disassemble a Rubicon rear axle Tru-Lok carrier
- How to fix a broken Dana 30 vent tube fitting
- How to Install a Jeep Wrangler Front Axle U-Joint and Hub
- How to install Alloy axle tube seals
- How to install an ARB Air Locker
- How to install gears in your TJ
- How to Re-Gear a Ford 8.8
- How to re-gear your Dana 30
- How to re-gear your TJ axles
- How to Read and Interpret Gear Patterns
- How to remove the front spindle nut
- How to replace a pinion seal on your TJ
- How To Replace Rubicon Axle Air Fitting
- How to replace spider gears
- Installing Yukon Super 88 Kit - WF-88-31
- Jeep Wrangler TJ U-Joint Replacement
- Powertrax no slip locker installed
- Rear Dana 44 axle shaft seal and bearing replacement
- Regearing from 4.88 to Revolution Gear's new 5.38... sweet!
- Replace Dana 44 Rear Axle Bearing & Seal in 17 Easy Steps
- Revolution USA Made Front Axle Shaft Installation
- U-Joint Inspection
- U-Joint Replacement
Body/Doors/Exterior
- Bed Mounted Spare Tire Mount
- CJ grille (nose job) for the LJ
- Color correction: The details of detailing your Jeep's exterior finish
- DIY: How to make a hood latch lock for a TJ
- Door storage
- Doors-off mirror solution, cheap and no tools required
- Early TJ Tailgate Hinge Rescue
- Easy and Cheap Spare Tire Bumpers
- Front Runner Tailgate Table
- Homemade tire carrier
- How to feed inner bracket bolts for rear bumper replacement
- How to fix clogged windshield washer nozzles
- How to install a CJ tailgate on your TJ
- How To Install YJ Half Doors on a TJ
- How to Make a Permanent Stirrup Step
- How to mount mirrors to tube half doors
- How to order brand new factory Jeep Wrangler TJ / LJ parts to your front door
- How to Paint Your Fender Flares
- How to re-key half-door lock cylinders
- How to remove the AM/FM antenna
- How to Remove the Grille
- How to replace outer door handle rod plastic retainer with a better solution
- How to replace your factory front bumper
- How to reverse TJ door handles
- How to stop 05 LJ tailgate latch cover rattle
- How-to Repair Body Mounts
- How-to repair dreaded rear quarter panel rust
- How-To: No-Weld Rusty Floors
- Installing Rubicon rocker guards on a TJ / LJ that didn't come with them
- Luggage rack for my hardtop
- Paint correction: Restoring faded or scratched paint
- Replacing your TJ door hinge bushings with oil-impregnated bronze bushing
- The Wiper Arm Sprayer Mod: Your Windshield Doesn't Need To Be Filthy Anymore.
- XJ cargo rack on TJ hardtop
Brakes
- Extended Front Brake Lines
- Full Brake System Replacement and Bleed Process
- How to adjust brake switch
- How to bleed / replace your clutch fluid
- How to bleed your brakes
- How to change your parking brakes
- How to do a Brake Caliper Flip
- How to overhaul the front brakes on your Wrangler TJ
- Installing Yukon WU-08 Hub Kit (Similar to WU-07 Also)
- Rear Wheel Stud Replacement
Cooling
- Easiest fan clutch removal ever
- How to fix a radiator in the field with a Leatherman
- How to flush the cooling system on your Jeep Wrangler TJ
- How to install a Derale 20561 transmission cooler on your Wrangler TJ
- How to install a Ecoboost oil cooler / heater in a 4.0 and why
- How-to fix an overheating Android head unit
- How-to install a B&M 70264 Supercooler in your Jeep Wrangler TJ
- How-to Make a Custom Core Support Brace Cooler Mount
- How-to replace the water pump on a Jeep Wrangler TJ
- Jeep Wrangler TJ Water Pump Replacement
- Setrab transmission oil cooler 53-10748 reference pictures to aid some installs
- trying again - fitting a JKU radiator into a TJ as a transmission cooler
- Wrangler TJ Radiator Replacement
Electrical
- 12V Fan Bypass Relay
- 2003-2006 Hardtop Wiring
- Adding a flasher to your 3rd brake light
- Auto-dimming/Compass/Temp/Homelink Mirror for Wrangler X
- Backup and front camera install
- Blower motor switch modification
- Built-In Garage Door Opener Switch
- Bussmann Auxiliary Fuse and Relay Module Installation
- Cheap USB outlet behind glovebox mod
- DIY Auxiliary PDC / Fuse Box
- DIY booster pack
- DIY cordless quick charger for phone
- DIY third brake light contact repair
- Fixing a broken clockspring
- Front Wiper Motor Replacement
- Gentex 341 (map, lights, HomeLink, compass, and temperature) rear view mirror wiring connections to TJ OEM harness
- Gentex GNTX-221 Mirror Wiring
- Heated Side Mirrors and LED Turn Signal Repeaters
- How do you wire a on-off-on switch to run from the battery or the key on acc fuse?
- How to calibrate your speedometer using SpeedoHealer by HealTech
- How to clean 03-06 starter motor and replace brushes
- How To Create Anderson Connectors Jumper Cables For Fast Jump Starts and Dual Battery Redundancy Systems.
- How to disable the door chime on a Jeep Wrangler TJ
- How to drive home if your ignition pin actuator breaks
- How to Factory Wire Your TJ for a Hardtop Part 1 97-02 (Dash Harness)
- How to fix flickering fog lights or fog lights that won't turn off
- How to fix no 4WD dash light
- How to get steering wheel audio controls in a TJ
- How to install dual batteries in your Jeep Wrangler TJ
- How to install factory cruise control in your Jeep Wrangler TJ
- How to install factory cruise control on your TJ (2.4 version)
- How to repair multifunction switch for fog lights (fog lights that won't turn off)
- How to Replace a Clock Spring
- How to replace the headlight plunger switch
- How to replace the rear wiper motor on a 97-02 hardtop
- How to swap a high amp Dodge Durango alternator into your Jeep Wrangler TJ
- How to wire your TJ for towing behind RV or truck
- How to: High Idle Switch (Using Cruise Control Servo)
- How-to add a spacer to the horn switch on your steering wheel
- How-to add an extra O/D switch on the 42RLE
- How-to bypass the chip key
- How-to calibrate your odometer using OBD, GPS and a SpeedoHealer
- How-to fix an ignition key that won't turn (remains locked)
- How-to fix the annoying parking brake chime on 05-06 TJs
- How-to install a Gentex 177 compass mirror in a TJ / LJ
- How-to make a Speedohealer harness
- How-To Replace Jeep Wrangler TJ Ignition Actuator
- How-to: Troubleshooting a no-crank situation
- Installing a 3.0 dual USB plug / voltmeter
- NP241 OR 4WD illumination
- Passenger airbag switch light fix (which turned off cluster airbag warning light)
- Rear Defogger Without Factory Harness
- Replacing speedometer sensor
- Rubicon Locker Repair
- Sentry Key Immobilizer Module (SKIM) Install / Retrofit
- Setting up a kill switch (hidden in plain sight)
- Tailgate Dome Light Activation Switch
- Theft protection: How to automatically disable and enable your Jeep Wrangler TJ
- TJ Glovebox Light Install
- USB dash install for phone & thumb drive
- Using your existing relay box for adding electric accessories
- Waterproofing Your Jeep Wrangler TJ's Under Hood Electrical Components
- Wiring a five terminal lighted switch
- Wiring the 42RLE overdrive for off by default
- York OBA Installation with ORO Bracket, A/C, and Durango Alternator
Engine / Sensors
- How to change your oil
- How to change your OPDA
- How to change your spark plugs
- How to clean your IAC (Idle Air Controller) valve
- How to convert 01-06 block to fit into a 99
- How To LS Swap Your TJ
- How to perform a cylinder head swap on a 4.0
- How to replace a distributor the easy way
- How to replace the timing chain on a Wrangler TJ 4.0
- How to run a drive cycle in your garage to pass Texas emissions
- How to test your camshaft position sensor
- How-to change the 4.0 idler pulley and tensioner
- How-To Remove the Black Plastic Wiring Bridge On Valve Cover
- How-to replace a rear main seal on a Jeep 4.0 engine
- Installing a new flywheel
- Jeep Wrangler TJ Camshaft Position Sensor Replacement
- Jeep Wrangler TJ Crankshaft Position Sensor Replacement
- O2 Sensor Swap Walk-Through
- OBDII Scan Codes
- Oil pan installation
- P0153—O2 (Bank 2, Sensor 1) diagnosis & replacement
- P0301, P0302, P0303, P0304, P0305, P0306 (the dreaded misfire) and how I solved it
- Rear Main Seal Replacement (4.0)
- Rear Main Seal, Oil Pan and Gasket Replacement
- TJ Oldsmobile air intake conversion
- Tuning DFCO for better engine braking and fuel economy
Frame
- DIY Body Mount Bracket
- How to clean your Jeep Wrangler TJ frame
- How to remove and replace frame rail nutserts (BMB setting tool)
- Surface Shield: how to prevent leakage when using spray wand
Fuel System
- AEM high flow fuel pump install on 2006 TJ
- Gas Tank Removal
- How to check fuel pressure on a 2003 and later 4.0
- How to remove fuel injectors
- How to replace your fuel pump without replacing the whole assembly
- Wrangler TJ Gas Overflow Fix
Hard top/Soft top
- DIY Hardtop Dolly for $100
- DIY Hardtop Hoist
- Figured out the Bestop Sunrider
- Free DIY hardtop dolly plans
- Hardtop wiring: converting plugs to match different years
- How to Factory Wire Your TJ For A Hardtop Part 2 97-02 (Rear Tub Harness)
- How to Install Vent in Hardtop
- How To Paint A Hardtop Interior & Make a Custom Headliner
- Jeep Wrangler TJ Hard Top Repairs
- Safari top buckle trail fix
- Simple TJ hardtop wiring harness
- Soft Top Door Frame Threaded Pin Repair
HVAC
- AC Tune-Up
- Actuator vacuum line replacement, the easy way
- Another heater core replacement (and A/C Evap core)
- Defrost Vent Mesh Repair
- Have more control of your HVAC
- How to bypass the heater core
- How to eliminate passenger side floorboard leak in a 97 TJ
- How to fix a A/C vacuum leak under battery tray
- How to fix heat / AC / air not blowing through center vents
- How to install a cabin filter
- How to replace the heater core on a Jeep Wrangler TJ
- How to: troubleshooting blower (heater fan) problems
- How-To: Easy Peasy Dash Vent Filters for your TJ/LJ
- HVAC blower motor resistor replacement
- HVAC Slider LED Conversion
- HVAC Sytem Parts List
- On-Board Air Conversion of Stock Jeep Wrangler TJ A/C System
- Remove item from defrost vent
Interior
- 30mm Ammo Can Center Console with 8" Sub Enclosure
- 96-02 Sunvisor Mount replacement
- Adding a Tuffy Combination Lock to your Ammo Can Center Console
- Ammo case center console
- Console storage bump
- Dashboard Camera Mounts for TJ
- DIY Interior Cargo Rack for LJ
- DIY Leather Shift Boot
- How to build real door armrests
- How to fix loose steering wheel foam
- How to fix stiff lock / latch on TJ center console
- How to install a fire extinguisher holder
- How to remove center console
- How to remove sun fade with baking soda
- How to replace the center console lock on a 1997-2004 TJ
- How to sound deaden the interior of your TJ
- How To Take Apart Center Console Lock
- How-To Dupli-Color Your Tub
- How-to make a DIY tailgate table for your Jeep Wrangler TJ
- How-To: No-Drill Garmin Navigation Dash Mount for Wrangler TJ/LJ
- Leather Shift Boot Mod for 1997-2004 TJs
- Qi Wireless Phone Charging in Your TJ
- Secret secondary glove box on my TJ
- Tackform Dash Mount (No Drill)
- Tuffy's security center console installation
Lifts/Tires
- Are the 2.5" OME springs necessary in the rear?
- BMB 1.25" Body Lift
- How to find a slow leak in a tire
- How to install a body lift on your Jeep Wrangler TJ
- How to raise the rear frame and eliminate your butt crack
- How-to run JK or JL wheels on a TJ
- What kind of wheel spacers do I need to run these wheels and tires?
Lighting
- $16 Under Dash Light Conversion
- 12V Selectable Backup Lights
- Baja Designs IP6 DOT headlight install in a TJ
- Building and installing my own flush mounted LED tail lights
- Cheap 3rd Brake Light Extension
- Daytime Running Light Defeat
- Export Style (Amber Turn Indicator) Taillights - How To
- How to Add Custom 3rd Brake Light / Running Light
- How to aim and align your headlights
- How to Build Custom LED Strip Lighting
- How to fix a noisy light bar
- How to install an auxiliary backup light on the stock light housing
- How to install daytime running lights
- How to tap into the OEM under hood light for LED upgrades (or another under hood light upgrade thread)
- How to wire multiple fog lights to factory switch
- How-to stop a whistling light bar
- How-to: Installing auxiliary LED lights.
- Install LED headlights with DRL's, and Turn Signal indicators
- Installing factory fog lights on a pre-wired TJ
- Jeep TJ 50" LED Bar Installation
- My Install of the Toyota Light Mod
- Really Bright LED Reverse Lights in Stock Housing
- Refurbishing OEM fog lights
- Replacing the interior lights of your Jeep Wrangler TJ with LEDs
- Switch for reverse lights
- Upgrading the underhood light
- A semi-complete DIY highline guide
- BMB Steering Skid Install
- Bump Stop Check Walk-Thru With Pics
- Calibrating your deflators
- Currie Antirock Install
- DIY (No Drill) Temporary Snorkel
- DIY: Weld-in transmission cross-member and transfer case skid
- Estimate springs for use on coil-overs
- How to bypass TJ Rubicon Lockers for use in 4 High
- How to change a valve stem on the trail
- How to install a safety thimble on your winch
- How to install an ARB locker in your Jeep Wrangler TJ
- How to install JKU wheel on TJ spare tire carrier
- How to make a cheap awning for your TJ
- How to make your own CO2 air system for under $200
- How to make your own sway bar disconnects
- How to narrow a Ford high pinion Dana 44 front axle to waggy width
- How To Outboard Fox 2.0 RR Shocks
- How to outboard your rear shocks
- How to properly set your pinion angle
- How to relocate factory TJ / LJ Rubicon locker compressors
- How to safely carry a larger spare tire on a Jeep Wrangler TJ tailgate
- How to set your bump stop on a Jeep Wrangler TJ
- How-to install Currie tow bar mounts
- How-To Install Front Bump Stop Extensions on a 1997-2006 Jeep Wrangler TJ
- How-To: Simple Onboard Air for your TJ (Viair 400H)
- Inexpensive Rear Awning Build
- Installing Rusty's Off-Road Products Radiator Skid
- Jeep Wrangler TJ Rubicon Factory Locker Bypass (use your lockers in 4 Hi)
- M.O.R.E. 1" Bombproof Jeep Motor Mount Lift (MML) Install
- Modifying Poison Spyder Sliders
- Savvy engine skid install, with Fumoto oil pan valve (mated to OEM transfer case skid)
- Savvy Mid-Arm Install
- Savvy Under Armor / Skid Plate Install Write-Up
- TJ / LJ Rubicon Factory Locker Compressor Relocation
- Transmission skid plate install and video
- Triangular tire carrier upgrade
- Winch line to drum attachment WRG
- Yakima Roof Rack Setup on TJ Hardtop
PCM Related
