Genright mini boats on an LJ
Thank you.
It’s still not perfect, I have small gaps in other areas, and some nutserts didn’t collapse straight on. Doesn’t hurt anything but my OCD. I’m sure a more experienced installer would have managed.
What are you using to install nutserts? The wrench, nut and bolt method, or the tool?
I didn’t even notice my gap. I assumed it was normal. I guess I’m not as OCD as you. 🙂
So after weighting all my options for a functioning slider I decided on the Genright mini boats, as they did the best job at checking off the most boxes on my list.
To start with strip off those fender flares
For me I taped off the side up to the door to aid in marking as well as a little protection.
The next part is the scariest part....grab the hammer and bash that bottom seam. Also for me I cut a small wedge out of the bottom of the fender, you also need to do this for the tub to fender seam.
Next was to get the slider in place and centered. Get it nice and tight to the bottom,I used some clamps as well to get it tight to the tub. The first time I placed it up there it wasn't as tight as I wanted so I had to take it down and do a touch more hammering.
Get your holes marked, take down the slider and center punch the holes. Than drill your holes and install your hardware
I did a trial fit to confirm I got everything correct than I taped it off, wiped it down, and painted to protect the areas that the paint flaked off.
I chose to get them powder coated and know that when I mess them up I will just do touchups with paint. I also sealed just the top edd and down the sides. I also installed some aluminum backers inside the tub area.
I trimmed my factory fender flares and reinstalled them
Final results
Great job-
Do you mind elaborating on the notches at the flares and what modifications were needed to keep the flare secured?
Thanks, it pertains to one I’d like to fix.
Andy
Great job-
Andy
For me I decide to line them up and decide where I want to cut them, I didn't want to cut any more than I had to. I end up taking off Just enough to cut the whole backer off it's a good ⅛". Then when I reinstalled the factory hardware I put just a little bit larger washer behind them just to help support it a little more. Is it needed? probably not.
Reactions: Jamison C
Thank you so much. Your LJ looks really good.
Reactions: Steelyace
This is the tool they provided and it’s what I used.
5/16 Rivnut Installation Tool
Not sure what it’s called. I would probably try a different method if I did it again.
It’s a blessing and a curse 😅
Reactions: PNW_LJ
That is surprisingly affordable.
Where else have you used it? I’ve already replaced my frame nutserts and done with armor for now, so not sure where else these could come in handy.
I used the Astro version for the entirety of my corners and sliders. That was 50-60 nutserts. A rotabroach is also strongly recommended to get the 100 or so holes accurately placed.
Reactions: PNW_LJ and psrivats
Did you use nutserts on every hole for your corners and sliders? Or just the places where needed?
You'll learn more by not using a rotabroach. Use a dull sharpie to mark the centers, remove the rockers, and then drill them. If the bolts don't line up, you get to learn even more skills!
Maybe that's why some people buy a 2nd Jeep?
Reactions: PNW_LJ and jjvw
Thank you for the link @JMT ! $38 is the cheapest I've seen that tool go for.
@Steelyace do you think there would be any benefit to cutting 4-5 vertical lines into the body seam while folding it in? I'm wondering if bending it over shorter distances will provide a better bend.
Kinda like using a hacksaw for everything instead of having a grinder available!
  • USA Proud
Reactions: toximus
I'm sure that would work. If you're using a hacksaw you could always just cut a little wedge out of there. Mostly you need to be able to get that edge to about a 45° angle and you'll see how far up you have to go. It's not as bad as you think, and if you think you screw it up...... it's covered up anyway.
Just use a heavy rubber mallet or dead blow. Cutting reliefs is a waste of time. You are covering everything up. And a reason you aren't cutting up or cutting off the seam is because you are retaining the welded structure of where those two body panels meet.
On stock front fenders, there is one vertical rib that needs a small pie slice to allow for enough fold.
Anytime I need a blind nut. 😉
I’ve used on the inside of the tub for anchors/tie downs. I’ve used for corner armor, sliders. I’m not sure where else, but I’ve got my sons rig too, so that added a bunch. It may not be much help to you now.
Reactions: Woodrow and PNW_LJ
X2 on getting your own nutsert tool. I also bought stainless 304 nutserts instead of the brass ones. And 304 hardware. Ended up putting nutserts in lots of places...holding up the gas tank...filler neck screws. Doing everything in M8 or M5 for common wrench sizing.
