Let's Stress Test Our Newest Member....
I asked Googles Bard for ya:
A dual steering stabilizer may help to reduce the severity of death wobble in your Jeep Wrangler TJ, but it is not a guaranteed fix. Death wobble is a complex issue with many possible causes, and a dual steering stabilizer may not be able to address all of them. If you are experiencing death wobble, it is important to have your Jeep inspected by a qualified mechanic to determine the root cause of the problem. Once the cause has been identified, the mechanic can recommend the best course of action to fix it.
In some cases, a dual steering stabilizer may be all that is needed to fix death wobble. However, in other cases, additional repairs may be necessary, such as replacing worn or damaged suspension components. If you are considering installing a dual steering stabilizer to fix death wobble, it is important to talk to your mechanic to make sure that it is the right solution for your Jeep.
Here are some other things you can do to help prevent death wobble:
* Keep your tires properly inflated.
* Inspect your suspension components regularly for wear and tear.
* Avoid driving over large bumps or potholes.
* Slow down when driving on rough roads.
* Be aware of the signs of death wobble, such as a shaking steering wheel or a loss of control. If you experience any of these signs, pull over to the side of the road and stop driving immediately.
Reactions: hosejockey61
Is it really? Or is it still running in the background unbeknownst to even Chris, just WAITING to take over once it's learned enough? :oops:
It has begun!!!
large GIF
It’s logging everything and making dossiers for sale to those that want to exploit us.
You mean like Quadratec?
We surrendered 15 years ago when we swallowed the smart phone game and happily gave up any semblance of privacy.
I never did. I'm still rocking a flip phone.
