Hang on, did I miss it? Did you get the intake gasket on correctly and run it already?
You're a little behind the times buddy...
When I came out of the garage today when it was time to quit I had some visitors watching me.
Damn how did I miss that!! Hell yes good work it sounds great!
Still hoping I can make the Moab run in June but I ain't gunna commit to anything yet.
Hope to see you there and that rig on the trails.
While I was watching the paint dry I swapped out drop lights. The one I'd installed last month started smoking and making a buzzing sound. So it was unplugged and I ordered a new one.
This is the old one. I'll contact the vendor about it and see what they say.
New one installed.
While I was at it I also hung up a triple tap reeled extension cord. This should help to get some of the extension cords off the floor.
And now the paint is dry so I can install the crossmember.
Awesome. I need both of those and a retractable air hose.
Huston we have a problem!
I'd ordered a RuffStuff diff cover for the rear axle. I'd wanted to use the heavier cover as a possible help for the housing flex. Right or wrong my thoughts were it might help.
Well I'm not sure if it's the Super60 ring gear or? But it doesn't fit.
So I'm just going to install the stock cover for now and will contact RuffStuff about it and see what they say.
Not a show stopper but still a bummer.
None of you can understand the frustration when the pin lock won't line up when you're trying to put your leg back on....
Time for a billet spacer and some ARP studsAdapt or die!!!!!...
J/K
I think he is a master at adapting!![]()
