Interestingly I ended up on Bob is the Oil Guy and they will tell this is internet folklore because Currie and other companies would not share their testing data with them and that there is no way that synthetic oil is the cause of failure. What is being ignored to some extent is that after Ford retired the 9inch in 1985 the GL-6 oils they preferred were soon retired as well. This was also when synthetics were first coming onto the scene and since there was no call for GL-6 they just made GL-5. GL-5 does not have all the same additives that GL-6 did which are necessary for preventing gear scoring like in high offset pinions ala the 9. These same additives are also beneficial when running very low gears in diffs like the Toy 8inch, 14bolt and others where the pinion has more of a tendency to slide across the ring gear.
Isn't there a saying about trying to prove a negative? Just because someone won't share data does not make the conclusion of that data inaccurate. I chatted with John many times about that and it never varied. They warranty their rear ends. If they see a bunch of failures and determine causation between two different scenarios, one being synthetic and one being conventional, it doesn't take a genius to see what they will use to slow down warranty claims.
I also don't think many folks know that Currie actually built a gear dyno and used it for a bunch of things. One was to define the oil path onto the pinion bearings in the high pinion 3rds set up in fabricated and Ford housings. They had some clear plastic over areas so they could spin the gears both directions and watch how the oil got slung around. Same kind of stuff Banks did but well over 20 years ago.
Currie at that time had absolutely nothing against synthetics and said as soon as they found some that worked, they would use it.
