HandOverFist
Make sure to also buy a tub of "Assembly Goo" with the green label which is compatible with and dissolvable by ATF. It serves to hold things like the springs/valves in position while the valve body is inserted back up into the transmission.
It is really amazing. In a stop and go traffic, where I don’t even accelerate fast, the cooler kicks in in our every now and then.
It means that w/o a cooler, my transmission temperature would easily heat up to 200F+.
It was a crime to drive TJ with 42RLE w/o transmission cooler.
For almost 3 days that I am driving with a cooler, it didn’t miss the reverse even once.. I am starting to think whether all no problems were bad oil and overheat.
Transmission does not slip and does not throw any codes.
I went through the links.
I already installed a new Mopar filter, LubeLocker gasket, and a pan with drain plug through which I installed the temperature probe. Did all this yesterday night, after 2 hours of fighting with spinning nurserts.
Thanks for the link for the Solenoid pack.
My question is - did you just replace the solenoid pack,. Or also the range sensor? Did you disassemble the rest of the valve body for cleaning?
I added a Hayden in front of my rad & condenser & left the radiator trans cooler in place (so effectively running 2 coolers). Mine had been getting over 220F, hasn’t been over 160 since. It was on the heels of a rebuild so I didn’t have your problems, but yeah, can’t recommend the cooler enough.
counterpoint: XJ buddy says “let me get this straight, he only reason you’re worried about the temp is because you installed a gauge that tells you the temp?” XJ guys are a special breed.
Yeah, I was celebrating too early. It seems like there are less shift issues, but the sometimes not going into reverse is still there, just happened to me today. Next time when it happens, I will just keep it in Reverse in park, and will jump out to check whether the reverse light is on or not. If the reverse light is on, this means that PCM thinks that I am in reverse, if not, then the PCM is not aware and that means that range shift sensor is not detecting the reverse, and not commanding the solenoid valve to activate reverse.
The PCM controls the backup lights on the 42RLE?? Le sigh...
If this is not the case, can you clarify how it works?
I just pulled up the FSM for the 05, and it looks like the backup lights don't go through the PCM. 8W-51-1 is where the relevant stuff starts, if you're interested.
