Add oil through the check tube. I added 6.5 quarts, but I have Derale cooler,. Which adds some capacity. Initially I didn’t add enough (4.5 quarts only) and got this one. Added 2 more all was good.
Connect the battery.
Have an OBD reader ready.
Start the rig, keep the thing in park wheels in the air, no parking brake applied.
Check the oil level, it should be as in cold.
If oil level ok, go into each gear, see wheels spinning and nothing blowing up.
Read codes, see that nothing comes up.
Do multiple cycles in the air, like drive reverse stop
Park, 1, 2 etc. . If all is good, you are good to and mini overhaul is done.
