So Mfg States 15-18 MPG on a I6. Tank Capacity is 19 gallons. That's an average of 304 miles on a full tank. The most I am getting on a full tank is just over 200 miles. What is everyone else getting?
Yes, mine is 100% stock and a manual. I've tried driving as conservative as possible but it still seems like I'm losing MPG!Everyone's mileage is going to be different. Is yours completely stock?
1998 TJ 4.0i6 5MT with 4.88 gearing & 33" tires - 13.1mpg last road trip (I have a significantly cracked header, I'm sure I can do better). I nearly always fill up after using 16 gallons so 200 miles on the odometer basically.So Mfg States 15-18 MPG on a I6. Tank Capacity is 19 gallons. That's an average of 304 miles on a full tank. The most I am getting on a full tank is just over 200 miles. What is everyone else getting?
If you consistently get 18-20 mpg in a daily driven 4.0L TJ, it must be downhill both to work AND back each way, and you are in the top .5% of TJ owners, with either a 6 OR 4 cyl. engine...I get good mileage, usually 18 to 20 if used as dd to wk (mostly highway). Problem is I don't really know how far I can go past the low fuel light.
Usually hits low fuel light around 185 mi, but if I fill up right at the light I'm only able to get 9.8 maybe 10 gal at most.
98 Wrangler Sport 4.0 / 5 speed manual, stock 3.07 gears, n slightly taller tires on 17" rims (30.5 in per metric conv link found here in this great community). So actually getting better mileage as I'm going further than what odo shows.
Hwy 19, around town and off road 13-15. 2.4/6 spd/4.88/31's. Take that JMT!I have to be honest, I don’t believe it when someone tells me they’re getting 17+mpg in a TJ.
Ok, I accept it on the 2.4L since I have no experience there. Bam, that hurt...Hwy 19, around town and off road 13-15. 2.4/6 spd/4.88/31's. Take that JMT!![]()
