Let's see... a bunch of little things that have needed to be done for a while.
  1. New fan motor
  2. New windshield washer reservoir, pump, lines and nozzle.
  3. LED dash lights
  4. New lenses for the front blinkers
Still to do:
  1. New paddles/latches for both doors and tailgate.
  2. Remove and refinish center console and shifter housing.
  3. Remove and repaint front bumper
  4. Instal new front fog lights.
  5. Replace sliders.
  6. route and install back up camera.
  1. New fan motor
  3. LED dash lights
Still to do:
  5. Replace sliders.
Next?!!
Reactions: John Cooper
I have been metric since 1972 but I still say "He,s about 6' " and even 8x4 sheet or 4x2 piece of timber but to tell you the truth the metric system is just so much easier! Americans say 2x4 which is strange to me because UK and its colonies always said 4x2. Your money is metric your Drugs are metric lol! They should teach kids in US school both systems, I learned both and can still use the imperial system without thinking about it, your Gas gallons confuse me though I know it was the British who robbed you of the correct liquid amounts but you have had plenty of time since 1776 to put it right! :)
"WE" did put it right in 1776 !!!
turned off an idiot light
Let's go Brandon and Gavin Newscum too!
The front and rear pinion seals finally arrived along with the speedometer gear (37 tooth).
The 4x4 outfitter in Pataskala installed them along with the wheels and tires.
Cooper Discoverer AT3's at 31 x 10.5 x 15 on ION Matte Black 171's
I chose to have the raised white letters to the inside.
They also replaced the sway bar ends, that solved the instability I felt a few times.
I am going to comply with the demand for pictures... oh the shame...
First, the original wheels with tires dated in 2012 (5212) when I bought it in January.
The day it came home with the new tires and parts.
Cooper Discoverer AT3's at 31 x 10.5 x 15 on Ion Matte Black 171's
This morning with better lighting
I can't get underneath easily, still recovering from hip replacements.
I climbed down to see and poke at the frame the day I bought it. I needed a cane and walker to get down and back up.
Climbing in now with it raised up higher is a bit entertaining, but healing over time will help.
Well... I finished, finally, fully rewiring a CJ7 a couple months ago while putting a modern sound system in it with a back up camera... I'm still traumatized from that so I'm going to go with the easy mechanical stuff now to get my confidence back. I have the doors off and I'm going to do the paddles and refinish the panels and the center console as well.
Bumper and fog lights after that.
Git R Done !
Anyone know the thread size for O2 sensors? Instead of unscrewing the old sensor my Milwaukee impact decided to break the welded in plug/ bung section of the catalytic converter completely out lol I also found out that my converter is a fraud. Got the center skid sections primed up and the front driveshaft back in. Time to get the plate back on so I can get the rear trailing arm section cut out and replaced.
