Help Diagnosing Engine Knock
It serves no purpose to say, that's not it, just check it and move on to the next deal. Every person that has a noise similar to this should check the chain and move on. Skipping it because a few other people didn't have a problem with theirs isn't good troubleshooting.
Reactions: lBasket
My noise did go away and I have a video too. It's easy to check, saying it didn't fix your problem doesn't mean it wont fix another Jeep. You can test it in two minutes, not checking because of either of the videos is silly.
I never said to anybody in here to not check their timing chain. I never told anybody that's not their problem. I'm only sharing my troubleshooting experience, what I found and what I believe to be my issue, right or wrong. The OP checked bearing clearances and changed his timing chain to no avail. Did that stop me from doing the same to my Jeep? No.
I only stated that my noise did not get any better. I'm trying to share as much information as I can to help others.
Dang! All that and STILL got the noise? Sorry!
I checked the clearance of my bearings too and just like yours, they were all fine. Piston slap is really starting to be my main suspicion. It's super hard to diagnose. Have you checked your exhaust manifold for cracks by chance? I'm still suspicious of that for mine because of the way the noise quiets down as things heat up.
Looks like I missed this question. My manifold was the two piece design and had no cracks. I'm guessing they changed from a one piece to a two piece because of the cracking? No idea but it was in good shape.
Has anybody noticed the sound being worse after an oil change? I just changed my oil and I swear the sound is louder and taking longer to subside. I also believe that when I bought this Jeep last year that I didn't even notice a sound until I did my first oil change to it.
I can't imagine how putting clean oil in it is causing a change but this isn't the first time I've noticed a change.
[Engine knock/slap resolved]
Okay, this post is going to be winded because it's about a weeks worth of information in one. As my last post said, I recently changed my oil and the sound was more prominent and took longer to subside. This pushed me to the point of ordering a set of pistons.
I understand this isn't the 100% correct way to do what I've done but this is what I was willing to invest financially, physically and mentally to try and fix this slap/knock noise. I'm sharing to help people make their own decision but your mileage may vary.
My goal going into this was to order a set of standard pistons/rings, deglaze the cylinders and reuse all of my gaskets minus the head gasket. The gaskets have all been replaced 2,000 miles ago from my cam/lifters swap and the head bolts, according to the manual can be used twice. I planned on doing all of this in-frame and basically shade-tree slap some pistons in it and call it a day. Don't get too invested, don't stress measuring everything and checking tolerances, etc.
I ordered a set of sealed power standard pistons from ebay that included a Mahle piston ring set.
I started the tear down which didn't take too long since just 2k miles ago I had it apart replacing the cam and other components.
None of the pistons had cracked skirts. Just a note, this engine is from a 2003 although the Jeep is a 2001. Not sure if that plays a part but I ran the block numbers and it's a 2003 and has the TUPY head.
The skirts had a fair amount of wear but the cylinders looked fairly good. There was still cross hatching but there was also some glazing.
I planned on pressing the pins out of the connecting rods myself and heating the rods and installing the new pistons myself, also. In the end I did press them out with a 20 ton press but decided to have a local machine shop install the pistons for $80.
I usually take so many pictures but I failed to get pictures of the wrist pins and their condition. I couldn't feel any slop in the wrist pin when they were installed but after pressing them out they had a good amount of wear that you could feel with your finger and see. Some of the pins after pressing the rod off actually fell out of the pistons and hit the ground.
This basically destroyed the pistons but I had no plans of keeping them.
I ended up ordering a new oil pan gasket and manifold gasket just to be sure I didnt have to do it again (see more below)
Trying to keep this short and to the point, haha. I worked on it for 8.5 non stop last night to get it together. Fired it up today around noon. Fired right up, no noise. Ran it through some RPM ranges and shut it down to top off the coolant. Fired it up again and drove it around the block. Topped off coolant as needed and seen it was performing well enough to take it on an 80 mile journey (lol).
I've don't hot starts, mostly cold starts and I haven't heard the noise once. There's also noises that are gone that I didnt even know I had. I previously mentioned a noise while shifting gears that sounded like a power steering while, possibly. It was jn fact the pistons/pins, the noise is completely gone. The jeep sounds so much better. The bad news is I rushed the oil pan gasket and it's leaking pretty well out the back. I've confirmed it isn't the valve cover gasket.
Anyways, I do believe the problem is fixed and I did it for under $400, I think? (Excluding all the previous repair, of course). The question now is longevity and if my repair was done well enough to last. Tomorrow will be the first cold morning start but I'm confident it's going to do just fine.
I'll update and can post videos if anybody is interested and if the fix doesn't reverse itself. Hope this helps.
Wow, great job. So it sounds like wrist pins are the answer? I wonder what happens if they are never replaced? My old XJ basically made that noise from 50,000 until 250,000 miles, when I junked it because of rust. Anyway, well done.
Reactions: Harcust
I'm not sure if it's solely the pins. My noise was not present when first starting but came after about 30 seconds and slowly faded. I was thinking maybe the piston being aluminum is expanding faster than the pins causing an excess tolerance and noise. After a few minutes of running the steel pin heats up and closes the tolerance and the noise mostly subsides.
I'm no engineer and it's above my head all I know is I'm stoked because it sounds so much better but I'm also very scared that it's not going to last. *crosses fingers*
@Harcust very cool. Thanks for posting. Keep us up-to-date. Im sure once you get to over 5k miles you can call it a success. Or as it is, it's a success. Because that noise is annoying, though seemingly not harmful. Cheers 🥃
Reactions: Harcust
Anyone checked their thrust bearing clearance by chance? I neglected to check mine while I had the oil pan off and it's bothered me ever since. Could potentially cause a rattle if the crank is bouncing back and forth.
Although I don't know how that would fit in with the quiet-then-loud-after-30-seconds symptom...
Reactions: SkylinesSuck
I found someone on YouTube (who I think is on this thread) with this exact noise and directed the comments to this thread.
I have this exact same noise on my '01 TJ 4.0L 3 Spd and I posted about it on here a while ago: https://wranglertjforum.com/threads...er-2001-tj-123k-miles-32rh.55755/#post-982077
From what I have learned from local mechanics, this is likely a lifter or piston slap and to basically just ignore it til the engine needs to rebuild. I think I am going to try an oil change with Engine Restore and see how it goes. @ 125k by the way.
Has anyone had any luck with that?
That's me! Glad you found the thread! Thanks for sharing your experience as well!
Reactions: deleted
