You have a proper speed gear in your transfer case, that gives you correct speed and distance traveled.I am doing miles/gal
You have a constant point at which you fill up, from there you can tell how much fuel you added and how much distance that yielded.
Up to this point i have met 3 Jeepers who have claimed mystical fuel mileages. One was math retarded, other two were using bogus numbers for their math.
As @RMETeeJay said, any stored codes? If you have a misfire that throws a code, for example P304, Jeep will go into fuel consuming mode.
