What's the best way to stop water from entering here?
TJK
British Columbia, Canada
Been tracking a rainwater leak entering passenger footwell and I think I found the source. Foam gasket where cabin air assembly meets back panel if the footwell seems to get saturated and leak down.
What’s the best way to stop water from entering here?
I took off the cowl and cleared the drain. Any suggestions as to where the water may be entering if thats the spot where it’s getting in?
the air comes in from the cowl,probably getting a little water in their,that’s not designed to get in,when it does get in it will find the least path of resistance
the air comes in from the cowl,probably getting a little water in their,that’s not designed to get in,when it does get in it will find the least path of resistance all tjs rust out there,I have already repaired my floor.probably would have to remove the heater box and reseal it to the tub to fix it,easier to buy these
If I recall, the '97 TJ had a wide 3-section vent in front of the windshield, letting water dump right down into the HVAC system. Later models changed that. I don't know if blocking part of that 3-section wide vent would help. I think there were other factory changes.
My 2005 has a single vent section in the middle of the cowl, instead of the 3-section on the 1997. And it has this plastic guard over the HVAC downtube.
I think I remember reading about someone making their own rain guard kind of like this one. If I can find the reference I'll post it.
Reactions: TJK
You're right. My 97 has three vents in the cowl and no cover on the cabin air intake. Water can definitely enter through the open intake but I'm still not sure if that's the true source. If it were then I would assume the water would enter through the foot vent, though I could be wrong. The gasket around the intake is pretty worn out so I may just seal that up to begin with, though part of me does want to just flood that intake with water and see if it starts pouring in...
Does anyone know where this section (with the foam gasket in the pics) connects on the other side of the upper floor pan? I'm looking at a video by Bleepin Jeep
he has the whole assembly out but I can't quite figure out where this piece is on the assembly?
3:48 shows the location of it on the other side of the heater box. If you're looking for where it is when in the Jeep, it's somewhat hidden below the battery.
A few months ago I took this picture of some wear marks I could actually feel on my AC accumulator because the super fat wiring harness had been rubbing on it for maybe 15 yrs? Anyway, the battery is out and you can see part of the curved thing that Bleepin Jeep guy calls the down tube. It's at least a few inches below my two fingers that are blocking some view, if they were out of the way we'd probably see the whole thing.
I kinda doubt that rain water is entering the Jeep through that area, mainly because I don't think much, if any, rain water would get there to begin with.
Was the drain plugged up? If it was, the water that wasn't draining out needed to go somewhere. Of course even if it is draining that doesn't mean something else isn't causing your water issue.
I'm not sure what you actually mean with "just flood that intake with water" but if you pour water into the heater box it should leak right out through the down tube thing. Spraying water around the cowl/air intake area with someone else's head under the dashboard should help them find out where the leak is. Just start slow, if you spray too much water everywhere at the beginning and it immediately leaks you'll only have narrowed the leak's location down to just about anywhere.
I think that canister is the AC accumulator. Maybe it's really something else but it's part of the AC, which I know little about.
hhmmmm... odd.
I know most TJs are wired for stuff they may or may not actually have, but that seems like a big ticket item to install unless the rig actually has AC.
Thank you for the picture and the thorough post. I know that water is somehow getting to that joint and flowing down the back panel onto the floor. When I checked under the cowl the drain was actually quite clear. I cleaned it out anyway with a wire coathanger and flushed with a few gallons of water but there was very little debris to be found there. I have seen on this forum that a few members have sealed up that same foam gasket area from the inside but I'd like to find how its getting there in the first place.
It's raining another "atmospheric river" here today so I'll be inspecting and keeping this thread posted.
